Bwagz Posted April 2, 2022 Share Posted April 2, 2022 I’ve had crank so start for a while and I wanted to check my CAS, I pulled the CAS off because I just wanted to check the resistance but then couldn’t find what levels resistance should show. First question is that, second question is I just had a no start issue without crank, I thought it might be my battery that had gone flat because I hadn’t started or tried to start car in approx a month. I pulled CAS off, had a look, put it back on and then I got two very slow cranks followed by a continuous clicking, not sure if I installed the the CAS incorrectly or if it’s just a starter or battery fault. I added pictures and a video but I’m not sure the video worked. Any info would be appreciated. IMG_6641.MOV Link to comment https://www.sau.com.au/forums/topic/483514-no-start-followed-by-clicking/ Share on other sites More sharing options...
joshuaho96 Posted April 2, 2022 Share Posted April 2, 2022 Your battery is probably dead, sounds like you're losing voltage during the crank which is causing the relays to start clicking. Link to comment https://www.sau.com.au/forums/topic/483514-no-start-followed-by-clicking/#findComment-7962809 Share on other sites More sharing options...
