Hi,
Reposting as i now have the car sorted. Installed a brand new Apexi Power FC and Z32 80mm air flow meters. The car was tuned at Silverwater Automotive Services by Dave Alexander and made 440 Horsepower or 323.5 Kw at all four wheels running 1.3 bar boost pressure. (thats over 500rwhp)
I want to sell the car within the next fortnight so i would class this as an urgent sale. Please do not waste my time, last time i posted i spent a month being mucked around by time wasters.
For Full details see the back posting of my original thread which shows all of the details on the car....
Brief Details:
1994 BNR32 GTR (White) Imported from Japan by myself 18 months ago
60,000 Kms
Nismo instruments throughout
Greddy A-pillar temp guages (twin)
HKS EVC Pro boost controller
Apexi Power FC and controller
Apexi turbo timer
Nissan Z32 80mm Air flow meters
HKS full 100mm exhaust system
HKS stainless seperator dump pipes (heat wrapped)
BNR34 N1 Ball Bearing turbos
BNR34 N1 bottom end rotating assembly (pistons, rods, crank etc)
BNR34 N1 Head
Trust 9.1mm 264 Camshafts
HKS 660cc Injectors
4.2 L/min fuel pump
Nismo adjustable fuel pressure regulator
HKS CDI ignition type -DLI
Nismo Twin Plate Clutch
Cusco rear diff
Fully rebuilt Aragost Midori suspension kit
Midori Negative Upper Links
Cusco Strut braces front and rear
Tein Adjustable castor rods
Alcon 355mm 4 piston brake kit
Pagid Endurance race pads
N1 Forged racing wheels
245/45/17 tyres all round (20% rear, 50% front)
Midori Dry Carbon lower front lip (additional expense)
AND PLENTY MORE.....
Nothing more to spend, genuine 650+HP, well built engine, reliable and ready for track work....selling due to house committments.
$38,000 firm, absolutely no price adjustments from this price.
Tom Goold
Newcastle, NSW
Australia
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
