hi fellow west ozzzers
just wondering if anyone knows where to get some motul oil
been looken for awhile and nothing
trying to get my baby running smooth for the meet down kwinnana, this week
blew my mates ford xr6 turbo of the road yesterday so i am lookin foward to see what she can do against a fast car (he he)
hope to meet everyone down the track to put faces to names
cheers
https://www.sau.com.au/forums/topic/48455-chasing-the-motul/
cheers
Trevor Adams, agency is based in Malaga but can't remember the number.
Ring me tomorrow and can give it to you.
Cheers
Ken
https://www.sau.com.au/forums/topic/48455-chasing-the-motul/#findComment-974859
probably the only reason i was chasing the motul was the huge fan base and good reviews from members ,
just curious to see if it is as good as it hailed for
but steve from sst put me onto product called fuchs Titan supersyn sl 5w-50
from what he was saying its pretty good stuff and is what they use for all there cars
so i cant argue with that, considering how many cars go thru there shop ,so i will give it a go and see how it is
basically just trying to find the right product for me
a balwin oil filter and 5L $78.00
https://www.sau.com.au/forums/topic/48455-chasing-the-motul/#findComment-976119
where can i get some of this fuchs titan stuff? im slowly getting all the stuff i need,so when the 32 comes, i can do a full service etc etc.
steve
Steve - you need my old PFC/HC/Boost Kit!
Includes FREE oil and filter as decribed above when you purchase from SST!!
https://www.sau.com.au/forums/topic/48455-chasing-the-motul/#findComment-976192
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
