self_slaughter Posted August 6, 2023 Share Posted August 6, 2023 Originally pulled from an automatic Stagea. Has flex fuel kit / feature pack installed + comes with consult cable. Running base map to suit stock setup. Connector could do with a squirt of contact cleaner, but had zero issues other than tuners being reluctant to touch such ancient technology. $350 posted. Link to comment https://www.sau.com.au/forums/topic/484838-nistune-ecu-to-suit-rb25det-neo/ Share on other sites More sharing options...
leeroy_pat_12 Posted August 10, 2023 Share Posted August 10, 2023 Don’t have a loom too? Link to comment https://www.sau.com.au/forums/topic/484838-nistune-ecu-to-suit-rb25det-neo/#findComment-7981843 Share on other sites More sharing options...
self_slaughter Posted August 10, 2023 Author Share Posted August 10, 2023 Nah, just the ECU itself. Swapped it out for a Link unit a while back and has just bit sitting in the parts pile since. Finally had a purge and binned most of it. Figure this would still be of use to someone, somewhere. Link to comment https://www.sau.com.au/forums/topic/484838-nistune-ecu-to-suit-rb25det-neo/#findComment-7981846 Share on other sites More sharing options...
Wazmond Posted August 12, 2023 Share Posted August 12, 2023 Now im not too sure, but wouldnt there be an issue if you were to chuck that in another c34 stagea auto Link to comment https://www.sau.com.au/forums/topic/484838-nistune-ecu-to-suit-rb25det-neo/#findComment-7981906 Share on other sites More sharing options...
GTSBoy Posted August 12, 2023 Share Posted August 12, 2023 1 hour ago, Wazmond said: Now im not too sure, but wouldnt there be an issue if you were to chuck that in another c34 stagea auto Wotcha mean? Take an ECU out of one car and put it into another near identical car and....problem? Link to comment https://www.sau.com.au/forums/topic/484838-nistune-ecu-to-suit-rb25det-neo/#findComment-7981908 Share on other sites More sharing options...
self_slaughter Posted August 13, 2023 Author Share Posted August 13, 2023 Has the base tune loaded, so if you're using stock injectors/maf etc. It will just run as is. If not, it'll obviously need to be tuned to suit. Was running the neo in my manual R32 until recently. Link to comment https://www.sau.com.au/forums/topic/484838-nistune-ecu-to-suit-rb25det-neo/#findComment-7981923 Share on other sites More sharing options...
self_slaughter Posted September 11, 2023 Author Share Posted September 11, 2023 Can't edit the title to add a sold tag... but she's Gone Daddy Gone. Link to comment https://www.sau.com.au/forums/topic/484838-nistune-ecu-to-suit-rb25det-neo/#findComment-7982729 Share on other sites More sharing options...
