Hi Guys,
I have just recently picked up a 1995 series 1.5 R33 GTS-T manual and I couldn't be happier. I've wanted an r33 since I was a small boy and never really thought I'd get the opportunity to actually own one. In my home country they where so rare that I never even saw one in the flesh, only ever seeing one R32 GTR and an R34 GTR.
My car is pretty stock and just about to hit 200 000KM. Shes got a Blitz return flow front mount and pod cooler, blitz coilovers with GTR camber arms and  splitfire coils and a Mishimoto radiator. The body is in farily good condition with not much rust, a slightly torn front bar and pretty bad paint with massive seams in the clear. I've slowly been getting every mechanical issue sorted and so far have replaced the radiator and thermostat, turbo gaskets and manifold studs. I've pulled the rear lights to bits, cleaned and polished and resealed them and added new seals to stop the leaks as well as pulled out the boot body seal and re-sealed to stop the boot filling with water.
Cosmetically I've painted the plastic centre console trim, designed and 3d printed a triple gauge holder to sit under the aircon controls and replaced all the broken vents.
I got some fresh wheels at 18x9.5 +22 square and shes sitting pretty. The wheels fill the guards perfectly and so far no rubbing. The fenders have been rolled and I think for my height I have to pull the guards a bit just to eliminate any potential rub when driving spiritedly around my terrible roads.
I've already learned a heap from this forum and am very grateful for all the knowledge.
Thanks for having me!
Edited by mOs_cOWw
  • Like 3
https://www.sau.com.au/forums/topic/485136-how-do-you-do-fellow-kids/
Welcome.
Some points.
3 hours ago, mOs_cOWw said:
GTR camber arms
Same same to GTST.
Probably better to lift the car. The ideal eyebrow height** for R chassis cars is ~345-355mm. Any lower than that and you are working in the wrong part of the suspension geometry swing arcs and doing yourself a dis-service.
**As measured from the centre of the wheel cap to the lip of the guard above it.
If you want to run it loooow, you either have to install a bunch of extra parts (like drop spindles and do something to fix roll centre problems etc etc) or put up with it handling like a bucket of shit.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
