CES Split dump pipes
  • Replies 56
Guys, CES is one of the Best exhaust fabricators in Australia
Goto www.cesracing.com.au to read about them
All ive ever heard about CES has been good
$650 for this; HPC coated is awesome!!
If we get 10 im in definate.
Guest darrinspencer
Wizard count me in for sure as long as i can pick up the dump pipe within the next couple of weeks. I am very interested... Also what would be the difference between the plain steel and the HPC coated?
The $650 price is for 10 steel pipes HPC coated
If we split them up, some with HPC and some without It will adjust the $650 price
Prices quoted were broken up as
10 pipes $530 each plus hpc $120 each total $650 each
5 pipes $550 each plus hpc $130 each total $680 each
So depending on what option we end up with the final cost may be affected
One thing Trevor suggested was that on Skylines with their fairly low mount of the turbo the HPC would have a less of affect and you could get away from not using it.
Apart form the high heat reducing affect from HPC, it also stops the mild steel pipe from rusting, which IMO is worth while.
There seams to be a few GTR owners keen to participate in this group buy. If it was possible to include dump pipes for an R32/R33 GTR in the group buy I think you would make up the numbers required a lot quicker. I would be keen for starters...
Lawrence
Guest darrinspencer
Lawrence
We need to get 10 people for 1 type of dump pipe not a mix up of both
CES make 10 at a time, hence we need to get 10 people together for 32/33 GTST to get the better price.
To organise a group buy is a pain in the arse for who ever organises it.
Some people want one, some are interested but do not confirm if they want one, some want one then pull out when it is time to pay which really stuffs things up as it has recently happened in my last group buy for flywheels
I am only doing this so I can get a cheaper price for my car.
If you want to organise a GTR dump pipe group buy feel free.
Guest darrinspencer
Lawrence
I will be now including GTR as aswell
I will update the first thread soon with prices when I can fit it in between work.
Guest darrinspencer
Lawrence
GTR and GTST are now included in the group buy
Please read the first thread for all the details and prices
Please read the group buy rules aswell.
Thanks
NewB question... what the hell does the waste gate do?? Is it essentially there to create less turbulence as the two exhaust streams meet at a similar velocity?? I'm not too sure.
BTW this will bolt straight on to a stock R33 GTS-t?? If so, is it a DIY jobby?
(In case ur not sure ,I am seriously interested in one of these... just depends on when I can get it etc.)
Cheers.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
