Hi all
Haven’t posted on here for a while.
I was wondering if someone can assist with a problem I am having.
I have a 2005 V35 coupe. Recently snapped my drive belt.
Sourced a new belt which is recommended (6pk1180) in Bando brand.
Tried to fit it however too short and virtually impossible to get on, I even had a professional mechanic to have a look he tried to fit the belt without any success.
Has anyone else come across this issue? Possible fix?
Any help will be greatly appreciated.🙏🏾
Cheers
Rushdi
https://www.sau.com.au/forums/topic/485380-v35-belt-too-short/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
