Does anyone know the correct procedure to install the Tomei Hicas lock kit (elec and mech) on an R33 Gts-t. I've spent an hour searching the forums for it but came up only with the method for the R32.
Are they the same?? Wouldn't have thought so, due different Hicas on R32 vs R33.
Cheers.....
https://www.sau.com.au/forums/topic/48764-tomei-hicas-kit/
  • 2 months later...
Bringing this back up...noticed that many of you seem to not want HICAS in their R33s, yet provide little to no information about the Tomei Kit
Installation is straight forward, but i was wondering if anyone has translated the wiring diagram?
I think im going to have to hunt some japanese person of the street...
https://www.sau.com.au/forums/topic/48764-tomei-hicas-kit/#findComment-1081436
I have installed this on my R33. After much searching, I never found anything specific for the R33. Install wasn't too hard. I could never get the Hicas to go into test mode for inserting the second shim (maybe due to Power FC?). In the end I connected a car battery to the hicas motor on the diff which drove open the gap to insert the second shim.
I connected the little black box up but could never get the light on the dash to go out. I then disconnected both the HICAS motor and sensor to make sure it didn't go crazy and try and force the toe in/out.
https://www.sau.com.au/forums/topic/48764-tomei-hicas-kit/#findComment-1090797
howd u know which wires to cut into coming from the HICAS computer?
iv translated the whole instruction manual and all it says is "power cable, Signal Code A and Signal Code B"
screwed if i knew which of the bundle of wires they were...
Im waiting for Mark at Tilbrook to get back to me, should be today as iv asked around australia so far with no luck :(
The moment i get this info, ill post the sh|t up
https://www.sau.com.au/forums/topic/48764-tomei-hicas-kit/#findComment-1092284
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
