Hey Guys,
I have an R32 GTR coming from Japan in the next couple of months.
I have a pair of N1 turbos I will be fitting to it and also putting 3" Front pipes with 3" cat back, twin air pods and 1 bar of boost. I have heard this kind of setup should be good for about 250rwkw.
Now Ive had yes and no answers to this question, but would you remap the ECU for this level of modification?
My thoughts were yes due to the different turbos being fitted and the change in loads on injectors, fuel, afr's etc etc. But some advise that it is not nessisary for less than 260rwkw... What are your thoughts?
https://www.sau.com.au/forums/topic/49232-r32-gtr-tuning/
Im in the process of doing exactly what you are planning, R32 N1 tubs, front pipes and hiflow cat etc etc. I bought an R32 ecu and dropped it off to a guy called Toshi (see business for sale section) and he is fitting a new chip to allow me to run more boost and more fuel.
Can anyone suggest what power I should be making??
Let me know how you go with yours when its complete!
Lawrence
https://www.sau.com.au/forums/topic/49232-r32-gtr-tuning/#findComment-984842
I have a similar setup and have about 260rwkw, running 18psi boost and stock computer. The thing overfuels like crazy though at high RPM. More power easily available with tuning. If you are getting ECU work done make sure it is tuned on a dyno and not just plug and pray.
https://www.sau.com.au/forums/topic/49232-r32-gtr-tuning/#findComment-998284
I also agree, I think the extra boost I am running was negated by the over fueling. The dyno power curve is growing then it goes all lumpy and drops off etc. This happens about when the fuel ratio curve goes to over fuel. Once I get the fueling sorted I'm expecting to see a good power gain.
https://www.sau.com.au/forums/topic/49232-r32-gtr-tuning/#findComment-1002619
ha the figures you are talking about are a walk in the park with a strong health rb26 ,but i would suggest not to waste time and money on remapping or chipping (or even mines)as for around $1200 dollars you can have one of the best computers on the market APEXI Power fc and hand controller from nengun/greenline, trust me by the time you play with the others and dyno costs you could of pay for one. Best bet is to find a tuner with data logger to do the orginal tune as it saves about 4 hours and on a dyno thats $$$ and if you deside to go further a few small investments in key areas and you can really bring the rb to life
mine has garrett bearing turbos 320hp (similar to n1 size)
rb20 afm($300 for both)
700cc sard injector($691)
tomei cams and cam gears($1050)
apexi pfc($1230) and avcr($600)
and i hand made exhaust and inlet
rest std
and made 518hp(18psi)
at about 11psi it still made well over 400hp
i was pretty happy with the return on money spent
https://www.sau.com.au/forums/topic/49232-r32-gtr-tuning/#findComment-1002791
The mines ecu has alot of fuel in it.
if i was going to modify the ecu or replace it, i will definetly go power fc. these are designed for the gtr. and cheap thru greenline/nengun. only reason i use a mines is because it came with the car.
u have to make sure u got a healthy 26 when u start pushing 400's.
i have attach my dyno sheet, if you guys wanted to have a look.
https://www.sau.com.au/forums/topic/49232-r32-gtr-tuning/#findComment-1003391
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
