the proxy at work wont let me look at that..
anyone give me a rundown?
This is what is says
Make: Toyota
Model: Sprinter Trueno AE86
Gear: Version 2 Specs:
ECU/Engine/Exhaust
AE101 Wagon Engine
(Final Production Release, TRD Group A based engine)
TODA 288 Degree Intake & Exhaust Camshafts
TODA High Tensile Valve Springs
TODA Adjustable Cam Gears
Port & Polished head
Quad Throttle Body to Air
TRD Engine Mounts
TRD 0.8mm Racing Head Gasket
Revolver Full Aluminium Racing Radiator
Carbing Radiator Overflow Tank + 1.1bar Radiator Cap
Cusco Oil Catch Can
Custom BEL Garage 19 Row Oil Cooler
NGK Iriway 7 Spark Plugs
Honda Type-R Ignition Leads
Microtech LTX-8 ECU
Sequential Fire Coil Packs
Compression ratio - 11.9:1
Suction and Cooling
Revolver Aluminium Radiator
Earl's 19 Row Oil Cooler Kit
Davies/Craig Electric Thermofans
Throttle Body Filter Socks
Drivetrain
TRD 2 Way LSD
4.3 Final Gear
JDM T50 Gear Box
TODA Racing 3.7kg Chrome-moly Flywheel
Exedy 3 Puck Brass Button Racing Clutch
Handling
Disc Brake Rear End Conversion
Spirit Rear Brake Discs
Mugen Front Brake Discs
Mazda RX7 Caliper Conversion
Custom Coilover Conversion
Tokico HTS Dampers
KG/MM S21 Racing Springs
Safety 21 6 Point Roll Cage
Interior
Defi Tachometer + Shift Light
Defi Oil Temperature Gauge
Defi Water Temperature Gauge
Defi Fuel Presssure Gauge
Exterior
JDM Spec Trueno Front End Conversion
Full bare metal respray in Panda colour scheme
Watanabe 14 inch rims with Dunlop FM901 street tyres
  • Replies 101
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
