Added a few little bits and pieces to my car of late, just thought some people may be interested. Should all be ready for the next drift comp at mallala october 9th. Has all the usual mods cooler, boost, exhaust, with the current addition of coil overs, huge breaks, bigger gear box (RB20), repacked LSD and few other bits and pieces.
MY DR30
What you all think? She's a bit of a coon dog but ya get that with me.
https://www.sau.com.au/forums/topic/49455-my-dodgy-dr/
I'm thinking about going two tone now (white and black compared to your grey and black.
I duct taped the entire lower half of the car yesterday and its growing on me
Adam you have to much time on your hands dude,if u wanted to see white over black why didn't you just suss my car out!!!
Josh you figured the camera out that day then??? Its looking good dude,can't wait to see u and Tom out there sliding together, pity the crimmo mobile will never be seen sliding on a track :D
https://www.sau.com.au/forums/topic/49455-my-dodgy-dr/#findComment-992098
What happened to it?
I couldnt be bothered driving to your place Shane.  Its still on there btw lol.
I put the Tekamon lights and filler back on though
So u should as well!! Tekamon is where its at!!
Crimmo blew the gearbox in his car so he's selling all his good stuff off of it and selling the car as a rolling and running RB20..I've shotgunned the suspension and brakes, catch can, front lip and his cooler... :whackit:
https://www.sau.com.au/forums/topic/49455-my-dodgy-dr/#findComment-992484
I shot gunned the cage, and sway bar once he comes up with a price. YAY.
Looks like I got my hands on a free VG30 BB turbo for some downlow fun until I can afford something better. 1 week and she'll be on the road with any luck. Get off your arse Shane ya slacker.
The wheels arent impul but some thing or other racing made in italy. Dont ask me, I just love them I'm the anti-dished.
https://www.sau.com.au/forums/topic/49455-my-dodgy-dr/#findComment-993020
Josh the thing has panels now!! Im just waiting for Jaustech to get back to me about a bumper, goin to get the dump pipe off of that exhuast this week and its slowly coming together..Its gonna eb a good couple of months though be4 i get that stuff from crimmo most likely, specially the suspendion thats gonna be a long save lol!! Needs painting then and an ecu installed and tuned!! Christmas time me thinks...
https://www.sau.com.au/forums/topic/49455-my-dodgy-dr/#findComment-993628
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
