gtr33 crank in perfect condition $250 SOLD
gtr33 front balancer done only 1900kms $200
gtr33 pistons and rods in perfect condition $400 the lot
gtr33 oil pump in perfect condition $120sold
gtr nismo n1 main studs brand new $150new price $120
gtr33 alloy bonnet painted in gtr purple, perfect condition $700new price $650
gtr33 mirrors painted in gtr purple in perfect condition $200 the pairnew price $150pair
os-giken twin plate clutch, push type, still got 1.5mm left. $680new price $600
greedy pleunm to suit gtr all done in chrome and comes with 4' intercoller pipes as new $1200 the lot
brand new hks pistons to suit gtr $3500
18x10AME wheels to suit gtr, comes with near new 265x35x18falken tyres, the lot for $3600
[email protected]
https://www.sau.com.au/forums/topic/49553-skyline-gtr-parts/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
