1 of the most powerful street S15s in Australia)
Year: 2001 model (car in immaculate condition - motor done less than 1000km on dyno - never ever street driven)
Detuned for street. - Custom 600HP garrett roller application by RACE PACE.
Engine : SR20 DET - Tough as nails non-stroked JUN/TOMEI/HKS SR20DET
SPUN a conservative 477.5 rear wheel kilowatts on Race Pace Dyno in April 04 just before MAS04 with T51R SPL setup.
With new turbo setup - should see around 500HP.
(NOTE: ALL PARTS IN CAR -inc motor, turbo, handling, wheels, bodystyling ARE BRAND NEW - NEVER STREET DRIVEN - ONLY FOR SHOWS.
MODS:
- NISMO 1000CC INJECTORS
• JUN 1.6MM METAL HEAD GASKET
• JUN PISTON RINGS
• JUN SR20DET BOTTOM END BOLTS
• JUN SR20DET HEAD BOLTS
• JUN SUPER FORGED CONRODS
• JUN SUPER FORGED PISTONS
• JUN TITANIUM VALVE RETAINERS
- Jun - machined forged SR20 prepped block (sleeved and wedged)
• O RING BLOCK
• PORT / POLISHED HEAD
• TOMEI CAM PULLEYS
- BOSCH external fuel pump with custom surge tank
• SARD FUEL REGULATOR
- Tomei - poncams
- Tomei titanium valve springs
- Tomei solid lifters
• HKS HI’POWER 3inch CAT BACK EXHAUST SYSTEM
• HKS LASH KILLER KIT
- Exceedy twin plate
• ARC ENGINE SUMP
• HKS Type R (108mm) Drag INTERCOOLER
Micro tech LX series
- Bosch individual coil packs
• 18INCH MAGNESIUM F1 TECHNOLOGY RIMS (worth $6000 new,not a scratch on them)
• CUSCO BRAKE CYLINDER BRACE
• CUSCO FRONT STRUT BRACE
• CUSCO REAR STRUT BRACE
• CWEST CARBON FIBRE BONNET
• D-SPEED WIDE BODY FLARED/GILLED FRONT GUARDS
• CWEST FULL BODY KIT
• JIC MAGIC COIL OVERS
• NISMO CLEAR INDICATORS
• NISMO REAR ARM ASSEMBLY
___HAVE RECEIPTS FOR PARTS THAT TOTAL $32,000 PLUS___ not inc labour or purchase of car.
FAST FOURS COVER CAR - plus featured in many Aust tuning mags as one the best built street S15s in Australia.
MELB AUTOSALON / SYDNEY FINAL BATTLE / GLO SHOW DYNO AWARD WINNER.
NO OFFERS - GOING INTERSTATE FOR WORK SO HAVE TO SELL - $48,000
******* dont pm me on this forum - pls contact or sms me on 0412414173****
Hi.
I will SMS you but for everyone's info, is the airbag intact and other such considerations for interstate buyers who may have to get the vehicle inspected for registration? Has it ever been involved in an accident? I assume it is an Australian delivered 200SX, not a Silvia? Is it a Spec R or Spec S? Manual or auto? The mods list is comprehensive but other info is required.
Thanks.
PS. You get a free bump...
Hi.
Thanks.
Hey I didnt get an sms from you, but to answer you questions: yes the drivers side and passenger side airbags are intact. No accident history what so ever, but has had a few slight key marks from jealous on lookers at car shows. Yes it is an australian delivered vehicle - manufactured in april 2001. Its a Spec R, and yes it is a manual (smirk ;P). yes the list of mods are extensive, so extensive, not all new mods were mentioned in detail. Trust me, an offer like is very hard to come by. Give us a call if you want further info on my car, as there have been so many potential buyers flying from all states to Victoria to see it, but no one has yet to come up with the money. As the saying goes : money talks..... bu11sh1t walks. Have a nice day.
BMT
May I ask which rims are on the car - from the above pictures, the gray or the gold?
Whats the interior like? condition? any gauges, stereo installed????
Thanks
Daniel
It'll have the silver magnesiums on it. 18 by 9 and 10 rear. they have 33gtr brembos on the front with project u slotted & crossed drilled rotors, and standard rear with endless pads.
Car will be taken off the market at the end of the month. Possibly will be keeping it as too much money has been spent. As the saying goes........... money talks...... bu11$hit walks
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
