They're going out of business becaue no-one likes to pay for games. Y'all just want to download everything for free. Don't get me wrong it's great to be able to download the games for nothing but, if you like them, buy them.
Richard
https://www.sau.com.au/forums/topic/49818-juiced/page/2/#findComment-1027435
  • 4 weeks later...
Nice conection there, but its on xbox. There needs to be a pc version, its not out yet, suprnova does have torents for the ellusive pc version is not there, in conclusion.... dam you funkymonkey
EDITED: Skyzer
anyone that wants any info on getting this game like the monkey which is funky here are the links to places to accually DOWNLOAD THE GAME
bit torrent client (needed for download you dummy)
www.shareaza.com
Bit torrent site.
Once you have shareaza installed simple go to the following site, there all good as gravy
www.suprnova.org
www.torrenreactor.net
www.bitgoogle.com (might not work)
and then find the game, and using shareaza anti martin technology(it means its good)
it then loads the torren (dat file) and it downloads !!, the downloads start of slow as they should, then they go pretty fast pending on how many sources there are, if its a new game that everyone wants then you will get it in no time.
in conclusion.... there is no conlcusion.
Thanks 4 that i was using an old Bit Torrent downloader and wasnt getting jack, hopefully now i can d/l again! Luv getting Dave Chappelle show and Will and Grace eps. Cheers!
https://www.sau.com.au/forums/topic/49818-juiced/page/2/#findComment-1083494
Oh BTW played a bit of Juiced and totally agree top game, gives NFS: UG a run for its money!!
My fav paint:
Base: X25 Y9
Metalic: X14 Y9 (+75%)
Pearlesent: X34 Y13 (+80%)
Try it u wont be disappointed!!
How do u guys play online, do u have a switch to turn ur xbox chip off? Can u just plug ur xbox in with the same cord u use for ur modem or cable connection that goes to the pc?
Cheers
https://www.sau.com.au/forums/topic/49818-juiced/page/2/#findComment-1083499
i personally dont play online, but yes i do have a switch so i can simply turn my chip off.
To play online you need to register with XBOX LIVE and just network your xbox to your broadband connection... possibly through an interface hub or switch... or you can rip it out of your PC every time you want to play online
https://www.sau.com.au/forums/topic/49818-juiced/page/2/#findComment-1083681
yea, costs a little extra ($10-20) but its worth it in my opinion because xbox live wont run with a mod chip on unless you get new software of something like that.
Its basically just a switch at the back where the plugs are.
What i like bout the Chip is that you can customise backgrounds (i got Jessica Alba :(), startups and even install emulators n stuff
https://www.sau.com.au/forums/topic/49818-juiced/page/2/#findComment-1092984
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
