Guest two.06l
We have in stock 600x300x76mm bar and plate intercoolers for $550 inc gst.These coolers suit skyline, silvia, 180sx,rx7 etc .They are of top class construction featuring 3' inlet/outlet, mounting lugs and polished end tanks. They are of limited supply and will be sold on a first in, best cooled basis.Paul...DIRTgarage.9881intercooler1.jpg9881intercooler2.jpg
https://www.sau.com.au/forums/topic/49890-intercooler-sale/
Guest two.06l
pics have been posted 31/8
https://www.sau.com.au/forums/topic/49890-intercooler-sale/#findComment-996146
Hi mate very interested in the FMIC.Would u happen to intercooler kit for R33 GTST.
https://www.sau.com.au/forums/topic/49890-intercooler-sale/#findComment-997160
looking into these for a friend .. i have one ready for install from modyourcar.com.au looks damn near the same .... these seem to be a VERY popular and definate bang for your buck buy for any turbo car. only difference is the price. even though MYC have sold out both batches b4 landing.
i'll let me bud know about this.. i'd reckon he;d still be keen as mustard.
Matt
Specs w0uld be pretty much the same deal.
Construction: Bar and Plate
Core Size: 600x300x76mm
Overall Size: 780x300x76mm
Details: Comes with end tanks, fully welded.
Inlet Diameter: 3-inch
Outlet Diameter: 3-inch
Finish: Polished
HP Rating: 500-600hp
Flow Test: 381.3cfu
https://www.sau.com.au/forums/topic/49890-intercooler-sale/#findComment-999358
it looks the same so it must flow the same? cmon mate - not meaning to say these arent good flowing or looking coolers but that's not enough for me.
i was wondering if there was any more info on who where what made em and if they've been flow tested?
two.06l?
https://www.sau.com.au/forums/topic/49890-intercooler-sale/#findComment-999595
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
