wing sold
but i actually have another one but its not painted and no decals $150 also would be willing to swap for some parts of similar value,
eg, second hand 17" tyres 245 to 265's, or a boost gauge, make me an offer!
https://www.sau.com.au/forums/topic/49920-r33-gtr-wing/#findComment-997248
hmm let me think about it, if i had a few extra $$ laying around to have it sprayed then i'd take it right off you. let me have a look at my funds, i'd say it'd be around $200 to have it sprayed? hmmm, maybe i can sell my high bomex wing.
Mr_G: not sure of a part number, its just a red slimlime light that attaches to your rear window, then you simply run one wire to an earth and tap the other wire into your rear brake light.
https://www.sau.com.au/forums/topic/49920-r33-gtr-wing/#findComment-997263
wing sold
Hey mate....would you consider C.O.D the wing to my end ?( QLD )for $150 ? that includes shipping..or i could direct deposit...$150 including shipping..let me know if you're ok with that...assuming this'd fit R33 GTST S2 right ?
https://www.sau.com.au/forums/topic/49920-r33-gtr-wing/#findComment-997477
Cool, thanks for the info, ill go take a look at autobarn sometime soon cause Im in need of one :)
Thanks mate!
https://www.sau.com.au/forums/topic/49920-r33-gtr-wing/#findComment-998116
  • 2 years later...
