How much is my toy worth?
I have a widebody Z31 in mint condition with the following mods putting out 475rwks at only 20psi and BP98 on a DD dyno
Some of the mods included are
Widebody kit
2.7L N1 RB26 with nismo oversized pistons
Full GTR twin TDO6/20G kit with 68mm external wastegate
Fully race prepped R33 gearbox to handle 1000HP
OS triple plate clutch
F-con Pro silver
GTR brakes all around
Lots of suspension mods
Fuel system for a 1000hp
The big trust oilcooler and relocation kit
Big trust RSP intercooler kit
nismo 2way LSD
And a tone more but you get the idea
This car has a very safe tune. The most amazing thing about this car is you can do 10back to back runs on the dyno and the intake plenum is still cool to touch
https://www.sau.com.au/forums/topic/50520-how-much-is-my-toy-worth/
I have had the opportunity to see this car in real life (and see it running, and see it on the dyno, it even has my old cat on it :rofl:) and it is a simply amazing machine. Not a cent has been spared on this car, I heard of it and before it actually arrived had it in my head it would be a bit of a rough conversion, but upon seeing it, its immaculate.
Definately a unique car, and its still streetable... when you want to let go of it make sure you tell me first :(
Interesting no-one has answered your original question!! This is a tough car, sounded great on the Dyno!! At a rough guess I would say the parts value is over 40K (just quickly in my head, not including the car). Very difficult to say what value anyone could place on the package - has the mumbo to runs some very low numbers on the strip.
If someone had the cash and were after a car to decimate the opposion (and appreciated / was a Zed enthausist), then I'd imagine ~38K-55k??? hard to put a price on it, you need to look at the cost of building up something similar...
What about you ljstt & Amaru?? Anyone else??
come on DANOOH its a bit like asking how long a piece of string is, with out knowing every detail its impossible to know what its worth, is the paint perfect, has the interior been upgraded at all, do you have any proof like photos of build to prove it has what you claim etc etc or was it imported like this and you are passing on the list of mods you were told its meant to have
As for my question about the gearbox, I know of a car with same turbo set up that blows 3rd gear in a trust gear box just coming on boost so without exact specs and detailed pics how can anyone know what price its worth or isn't worth :rofl:
yeah point taken but i'm just looking for some feedback and some ballpark numbers.
The car was built in Japan, I even had it down tuned and a new nismo 2way LSD done before it arrived. Like I said its in mint condition I spent 1k just having this thing inspected in japan.
Anything over 7000rpm in 3rd and even 4th gear you have to go easy on the gas or it brakes traction.
