My GTR screams/whistles it's tits off when it comes on boost.
It's not the intake pipes, been checked.
It's not the Intercooler pipes, been checked.
It still boosts properly and is not down on power.
There is no extra exhaust noise.
There is no smoke, fuel or oil.
It still idles/drives perfectly except when you start to boost.
The noise is akin to a giant frog humping a Boeing 747.
Any ideas?
I was thinking a gasket around one of the turbos (hoping) or worst case, the turbo itself (which it won't be because I said so and I am not paying for new ones so they must be fine...:rofl: )
https://www.sau.com.au/forums/topic/50576-what-the-hell-is-this/
my car used to do this, i was still getting boost etc. turned out 2 of the studs that hold the turbo to the manifold had sheared off, and the manifold had warped slightly. not sure if this is the same noise though.
bov leaking a little? or else id suggest a manifold leak somewhere perhaps
Possibly but they on the other side of the car (although they do plumb back over to the other side) and the car isn't running rich so I can't see it being the pressure side of things.
Honestly would have to hear if it's more of a mechanical squeel or a high pressure air-ripping noise.
Maybe that's that noise I heard at Griffitth the other day...and I thought it was Mothra and Godzilla fighting
Starts as a whirrrrrrr then an almight scream. When it's low it sounds mechanical-ish but but once it's screaming it's air and lots of it.
So you've got both....that's just greedy :rofl:
Hmmm sounds like a listen and point mission, just get someone to give it a good rev while you stick your head under the bonnet...once you've got a fairly localised point of refererence you can start arranging a bank loan to cover the faulty part :D
Not the water pump is it....I had one that sounded like a banshee?
When it's free-revving it's fine, only under load and boosting it makes the noise.
Yeah sorry, without being there I can't really start to make any more conclusions on it...being under load, you'd assume it must be turbo related....maybe a hose has got a slight leak...like the squeeling a balloon makes when you pinch the end of it????
That's what the exhaust shop said but be buggered if I can find it!
it's the gasket or gaskets between turbo and manifold.
happens if the bolts holding the turbo to the manifold come loose or off in my case.
I had one go missing and that corner started leaking and burnt through the gasket.
when you start accelerating, it is a whirr, then as boost goes up, so does the scream and pitch.
I didn't lose any boost or power at first but eventaully I could feel that it was slugish.
if you don't replace the gasket/s, it will eventually leak at idle and you will get like a chuff chuff sound sort of like a lawn mower at idle.
nissan turbo to manifold gaskets are not that expensive.. if I remember, on my r32 gtst, it was $27 from GCG turbo's in sydney.
that pack contained the gaskets between turbo and manifold and some smaller ones for the oil and water lines.
Ok, your explaination is winning so far! Sorry Dan :wassup:
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
