I am far to bored and upset with my car for sensible discussion so I'll put htis idea foward instead...
There has been many a discussion on Trust turbos being a glorified (or in some cases not even glorified) truck turbos.
So, can you take 1 x Canter turbo and add 1 x RB26DETT and make decent power?
That is the question I put to you all...
https://www.sau.com.au/forums/topic/50607-crazy-idea-number-28394792/
1 x Canter turbo + 1 x RB26DETT = jus about what Ben from racepace has on his GTR that currectly holds the marque car record or somthing for Phillip island
Are you serious? How big are these small truck turbos???
What's an old school TO4E like?
This discussion is far from stupid....I seriously wanted something like a TO4E for my car...a guy that put one on his RB25DE had almost none of the low rpm pinging that I suffered...and had fairly decent spooling on the 10:1 compression.
I say put the canter turbo on, you of all people shouldn't be scared of strying something out...oh GT+T master :cheers:
I don't actually have a Canter turbo, just that finding a cheap (read: free) small diesel truck turbo is easy as pie. Manifold and wastegate would be the expensive bit...
Can the factory log be modded to take another flange? Can't see why not...anyone tried?
Certainly can, I've seen some with a normal flange, a spacer (used to attach the gate) and then the different flange.
No good for a GTR though as we have two separate manifolds and the flanges face different ways to the 20/25 manifolds.
Hi Guys, be carefull, diesel turbos are not designed for the much higher exhaust gas temperature of a petrol engine. I have seen one die in under 5 minutes, the seals melted and it filled the dyno room with smoke (not from the tyres). :dump:
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
