I am far to bored and upset with my car for sensible discussion so I'll put htis idea foward instead...
There has been many a discussion on Trust turbos being a glorified (or in some cases not even glorified) truck turbos.
So, can you take 1 x Canter turbo and add 1 x RB26DETT and make decent power?
That is the question I put to you all...
https://www.sau.com.au/forums/topic/50607-crazy-idea-number-28394792/
1 x Canter turbo + 1 x RB26DETT = jus about what Ben from racepace has on his GTR that currectly holds the marque car record or somthing for Phillip island
Are you serious? How big are these small truck turbos???
What's an old school TO4E like?
This discussion is far from stupid....I seriously wanted something like a TO4E for my car...a guy that put one on his RB25DE had almost none of the low rpm pinging that I suffered...and had fairly decent spooling on the 10:1 compression.
I say put the canter turbo on, you of all people shouldn't be scared of strying something out...oh GT+T master :cheers:
I don't actually have a Canter turbo, just that finding a cheap (read: free) small diesel truck turbo is easy as pie. Manifold and wastegate would be the expensive bit...
Can the factory log be modded to take another flange? Can't see why not...anyone tried?
Certainly can, I've seen some with a normal flange, a spacer (used to attach the gate) and then the different flange.
No good for a GTR though as we have two separate manifolds and the flanges face different ways to the 20/25 manifolds.
Hi Guys, be carefull, diesel turbos are not designed for the much higher exhaust gas temperature of a petrol engine. I have seen one die in under 5 minutes, the seals melted and it filled the dyno room with smoke (not from the tyres). :dump:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
