Mr Gtst,
sometimes i go down there for change of scenery.
I'm the club manager at Osborne Park Zest, read the sponsors section as I have created for Osborbne Park a corporate membership for ALL Sau members, $150 per year cheaper than what you guys have already paid......
Most of the SAU guys are already on this....
Come see me at Ossy Park when ya ready and i will get it sorted out..... oh and yes when you sign up with Osborne Park you can then use Kingsway at no extra cost :-)
AHAAHH!! Big Simon?? I know your sister then:-) SMALL WORLD HUH!! Tell your Sis to fix simons hair.... looks like last of the Mohicans.... Simons a champion though! Awesome manager!
of course i could always check to make sure he has reeeeeeealy looked after you... ;-)
haha yeah, he looks pretty scarey with that hair cut. which sister do you know? he's got 2!
i actually used to go to mirabooka zest but had to quit at the start if of the year. had to finish renovating the house before the wedding, so i was there every day after work and every weekend, and thus didnt have time to go to the gym.
we only started again last week, and as you can imagine Simons working me over big time.....
im sore as hell but its worth it!!
steve
hah who hasnt got one of these haircuts now?
mohawk and lines on the side. :D :throwup:
