Yesterday I install a brand new Hybrid FMIC to my r33 gtst.
about 12 months ago I had a SAFC installed and tuned as I had flat spots (running to rich) the SAFC fixed that problem.
I had being running 10psi before the cooler was installed but now I cant run anymore than 7 or the car seems mess and cough under load. I think this may be due to incorrect setting on my SAFC because now im getting so much more cool air. Do you need to get your SAFC retuned after the installation FMIC? Or am I on the wrong track what else could cause this?
https://www.sau.com.au/forums/topic/50907-problems-after-installing-new-fmic/
Using a FMIC will mean cooler inlet temps, so your SAFC may need a touch up tune.
Although the coughing and missing sounds like a spark plug issue.
Do you know what type of plugs you have and what size gap they are ?
J
Plugs are near brand new gapped at 0.8. pretty sure its no thats not the problem because the car was fine before the cooler went on. its hard to explain but the car is no realy missing its more of a hesatation might be a boost cut or something?
Your SAFC will need to be redone but i shouldnt have thought it would make it spluttery. When i done mine it still ran fine with the old settings. I would be checking for leaks, trying clamping it up a bit more. I encountered this after the first test drive with the new FMIC.
Checked all my piping connections all were nice and tight with no leaks. Called the guys form Ice performance they think that its probably overfueling again now that the engine is getting cooler denser air so im going to get it retuned Wednesday. I will let you all know how it goes.
Just suggesting something that you should check. I know it doesnt make sense, even in my case, but that's what the solution for mine anyway. I've had my dying pump almost a year before it was detected. On dyno the car made good A/F ratio of around 11.5:1 but tweaking the SAFC just doesn't want to change this. Very weird but the stock ECU seemed to compensate for the lack of fuel and fiddled with the timing. Only found out about the fuel pump when testing the fuel pressure and that's it. Got it changed over to a bosch item and the car is happy now with 12:1 A/F ratio and 192.5rwkw (before it wont go past 152rwkw in any boost level).
My guess, freer flowing FMIC means more airflow. More airflow is detected by the AFM and signalled to the ECU which is going into rich and retard (engine protection) mode sometime erroneously called "over boost" protection. You don't need extra boost to get it.
Just my guess of course, based on about 10 Skylines I have seen do exactly the same thing. :D
Thanks for all your replies Rs73 I will get my fuel pump checked out while it is there.
Sydneykid ive read some of your other posts about over boost protection and it made sense. If I understood correctly when I get my SAFC retuned it should fix the problem as they will be able to minipulate what flow the ECU thinks it is getting. Is that right?
Just my guess of course, based on about 10 Skylines I have seen do exactly the same thing. :cheers:
I get this exact symptom but ONLY when the car is cold... after almost exactly 15mins of driving it runs fine... go figure
I suppose it will get worse when my FMIC goes in... might have to get it looked at... lol *so lazy*
Before I got my SAFC mine did a similar thing to what it is doing now only not as bad. you probly need to one to funny it only does it when its cold.
Well I took my car to ice performance in melbourne yesterday. Found that I had dirty coil packs and my plugs wern't gapped to 0.8. The last time I took my car to a local macanic I had new plugs put in and I asked them to gap them a 0.8. So all this I thought they were gapped correctly when they were not. very anoyed. Anyway after the coilpacks were cleaned and sparkplugs were regapped the missfiring was gone. So they retuned the SAFC and the result was 196 Kw at the wheels on 10.5 psi of boost. very happy with that result and I recomend Ice performance to anyone.
I'm getting a front mount installed on the weekend.
Apart from full exhaust, pod (in cold air box), and electronic boost controller everything else is stock. Is there anything I should watch out for?
wil..
Regap plugs to 0.8 install the cooler and see how you go. But you may find installing a SAFC or simmilar will give you a lot better results as your ECU will probably see all the extra air flow and richen your air fuel mixtures with hurts performance big time.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
