Hi guys,
Im investing in an R32 GTR very soon.
Im just wondering if you guys can give me an estimate what power the following mods could give me:
R32 GTR
- 2 larger turbos (like HKS GT2530 or garret gt2530) not a real huge upgrade, maybe even just hi-flow the stock ones
- Larger intercooler
- Upgraded clutch
- Full exhaust
- Intake mods + CAI
- Boost controller (not set at a crazy boost though)
- Maybe larger injectors if really needed
- suspension and brake upgrades as necessary
- aftermarket engine management (power fc?)
All this with a stock head gasket, bottom end etc.
https://www.sau.com.au/forums/topic/5093-how-much-power-out-of-these-mods/
G'day Barks,
Based on a good friend of mine doing the same level of work to his '97 33 GT-R, I'd say a real world ~550+hp if set-up & tuned correctly. HKS 2530's will make more though!
To make the most of a package like you've listed (& using the 2530's) I'd add cams to your list.
Edit - You might want to add a f/pump & reg' upgrade too.
Yeah mate.
The list Ethan_R33 has posted above (including the HKS2530's) has the potential to make ~550+hp (410kw) @ the flywheel.
Or ~300+kw @ the wheels.
Cams will certainly help the 2530's, & Z32 AFM's would be a good idea too!
The stock bottom end & HG will be fine as long as the tuning is set-up correctly.
Gday.
Im making a Real World 280 kw @ the wheels similar mods to those Suggested.... the HKS GT25/30s are a perfect street turbo, I love mine! :D
Mine also has HKS Step 1 Cams and HKS 1.2mm Headgasket.
Andrew, how's it going? How have you been?
Gezzz, that's one hell of a car your looking at.
If you end up getting it and I'm over your way, I might have to con you into taking me for a drive...
I love that feeling of my eyes getting sucked into the back of my head :);)
J
HJB can you provide some specs on your car, im running a HKS single t45s with a 76 comp wheel out of a t51 SPL and i have 310kw at all 4 at 17psi, what sort of boost you runnin, also when does your turbo ramp up, or kick in ??? Are you internals stock, im hoping to see 500 rwhp soon-bout 360rwkw on stock internals i think it can do it, any comments or suggestions??
Originally posted by Ethan_R33
Hey Matt,
how are ya mate?
Yeah good mate :) I'm actually heading up to Mildura this weekend! So I'll drop in & say g'day :D You can see our little girl too :)
Send me a PM with your ph# just in case I've lost it.
CYA soon!
There still is a question over what has been done with the motor, plenty of HKS gear, basically all the mods listed above plus more, however the cat seems to restrict the power a little, so a new one is on the cards, also at only 18psi. The turbo starts to create boost at about 3000rpm, and on full song soon after, at this point you just hang on for the ride! :eek1:
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
