  • Replies 40
Depends on whether you want second hand or new? Nengun have new products (and second hand) and seem to cheaper than other suppliers. I've got most of my parts from nengun and never had a problem.
Greenline are sometimes cheaper than Nengun on some parts.
Depending on how mechanically minded you are I guess is to whether you pay someone to do it, or do it yourself. Adrian (strutto) has a fair bit of knowledge about the SAFC's, I'm sure he'd give you some information if you required it.
Tuners around the place. Theres the usual Autotech, Mercury Motorsport. Not sure about Matty Spry (I know he does PFC's, I gather he'd do other plug in parts).
I got both, i even got an SITC hehe
Only got AVCR installed at the moment though.
Buy through nengun. I got my AVCR as part of a group buy awhile back for $585
I think they are at nengun now for $615 or thereabouts
Installing is pretty easy, i did mine all myself. Just goto the USA Apexi site and download the instructions.
If youve ever mucked around with wiring/electronics before you should be able to do it. Can help you if you want.
And tuning of the AVCR is childs play, just takes some time to get the settings right.
Hmmm everyone wants a piece of me these days... :headspin:
Dot points:
- Nengun or Greenline for new...
- Installation is time consuming, but not difficult...
- Wiring does get messy around the ECU when you have more than 1 device...
- Dont stuff up the ECU wiring, its easy to do it around the wrong way...
- I had a SAFC2 and SITC before knore :) Mine are installed and working too :D
- Tuning is simple, but you need a dyno (or dyno printouts)
- I am the hero...
- Use solder, not the crimps supplied...
- I can help you to install and tune... I have previously done this on quite a few QLD cars...
- My cost is up to you... I won't have much time for you in the future if you decide to give me $10 or something... A carton keeps me happy ;)
Dot points:
- I had a SAFC2 and SITC before knore ;)  Mine are installed and working too :)
- I am the hero...
I hope that was not a dig at me , the rest of your reward is waiting till I see you next . I was planing on cash but beer is good what do you drink ? :D
It was a dig at you, not soley though... I've helped others and not even gotten a thank-you in return ;)
As the saying goes, talk is cheap and money talks...
XXXX Bitter... :)
yea even though everyone has already said it, nengun is where i got my SAFC II, its not that hard to install but can take some time. I think there may even be a thread on it in forced induction, do a search and have a look. If you dont have any idea what your doing then get some help as you have to cut and solder wires on the ecu loom (and you dont want to go screwing around with the wrong wires).
Good luck!
Matt
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
