Can anyone tell me how much room there is in the stock front speaker location to mount replacement speakers? Im trying to find out if there is enough depth for a pair of 6.5" MTX thunder6000 component speakers in the stock location. the site says the depth is 2.71" and i'd like to know if the speaker will skrew straight into the stock mounting position?
