i was looking at fitting a pair of Q45's to my GTR but i spoke to a few people about them and they said they were was to big and would be an asshole to tune, in stead i got a pair of nismo AFM's instead they fit straight up to the standard piping and plug straight in, there a little dear but a straight fit. 80mm same as z32
Hi, I have posted this table a few times, but just in case you missed it.
Rule of thumb for Air Flow meters RWKW & Engine BHP
------ ---- OD ---- RWKW ---- RWKW ---- BHP ------ BHP
No of AFM's ---- ------- 1 -------- 2 -------- 1 -------- 2
RB26 ------ 65 ------ 149 ------ 299 ------ 271 ------ 474
RB20/25 --- 80 ------ 226 ------ 453 ------ 376 ------ 683
Z32 ------- 80 ------ 255 ------ 511 ------ 415 ------ 763
Q45 ------- 90 ------ 302 ------ 605 ------ 479 ------ 890
Please note that this is only an indication, every engine is different and tuning makes a big difference. For example, I have seen a GTR equiped with twin Q45 AFM's make 1100 bhp.
RB20/25 and Z32 AFM's are all 80 mm OD, that's outside diameter, not ID that's inside diameter. There is no real difference between an RB20 and an RB25 AFM. On the other hand the Z32 AFM is calibrated differently, so at the airflow the RB20/25 AFM shows max voltage, ~5 volts the Z32 afm is only showing ~4 volts. This means when the airlfow gets higher the Z32 can still show voltage increases to the ECU.
Q45 (Infinity) AFM's are 90 mm (OD), so they have the same calibration advantage but they are also larger in diameter for less restriction.
Hope that helps
sydneykid your on it ,to for application up to 450rwkw the rb20/25 are a better afm because of the better sensitive ie air flow to voltage change . Only once you need more hp does the z32 come into its own and really how many car are in this league ?
So should I keep the Q45 for when I go a T51 or T88 or invest in a Z32.
What I want to really know is if this is goin to be alrite to tune or should I think about another angle??
If it's a GTR you really need 2 X AFM's to match the ECU requirements. So I take it you are asking if you should run 2 X Q45 AFM's or 2 X Z32 AFM's. Well the answer is in the table, if you are intending to run more than ~800 bhp then 2 X Q45 AFM's would be my recommendation. If you are intending to run less than ~800 bhp then 2 X Z32 AFM's would be my recommendation.
If you want to run the 2 X Q45 AFM's on the road, the engine will need vary carefull tuning. Two 90 mm AFM's do not have very much airlfow at low rpm to meter, so they are tricky to tune. If you have big cams they get even harder.
You should also be aware that getting a "Y" inlet (to connect 2 X AFM's to 1 X turbo) for 90 mm AFM's can be tricky. I have only ever seen one. On the other hand a "Y" inlet for 80 mm AFM's is relatively easy to get. Greddy, for example, have them off the shelf.
Hope that helps :D
SK your table is not correct, Z32 afm is fine for 330rwkw
EDIT: I know you posted its only a guide but maybe the single afm hp rating for Z32 and Q45 could be bumped up a but?
Hi BU5TER, it is only a "rule of thumb" minimum. If the engine is not using its airflow efficiently then the AFM flow rates are accurate. An "efficiently" tuned engine, with the right parts balance, will exceed the minimum. But if I used that, too many cars wouldn't make it, so I would much rather be conservative. :D
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
    • Nice shot! They look super clean. The roof rack delete on the black one is interesting. Would like to see more pictures from different angles. It's subtle but could make quite a difference to how the car looks in profile.
