Do you have the car beeping with the door open, and the keys in the ignition?
Mines makes a f**n annoying beep when the keys are in the barrel, and i open the door...im gunn rip it out soon :P
edit/ your factory central locking system is that loom above as well...its obviously been replaced and taped up inside....more labour to strip it out completely...just lazy people installing a/m alarm....
bl4ck32 - i'm pretty sure that beeping comes from a little box under the dash, which can be access by taking off the cover that goes from the fuse box to the centre console. its just mounted to the plastic with a white plug in it, disconnect that and u wont have that beeeping anymore (it worked for me).
Can you explain what you mean by your 'Edit' ?
My central locking box i found located in the bottom driverside foot well to the right. so im not sure what your saying?
F] This appears to be an LED inside a black case
Essential,
I have the same box in the drivers door of my R32. I think mine is just central looking, but i've never bothered to follow all the wires for it so it could be an alarm.
The only bits i've ever really taken notice of were the box in the door and the little black piece that you marked F. This looks like an infrared receiver for a remote. Unfortunately the remote didn't come with the car. In my car the piece marked F is clipped into the top of the door trim.
Next time i have the door trim off i'll see if theres anything else connected to it.
Maybe it was a factory option alarm or remote central locking system.
I'm fairly certain that this unit has nothing to do with controlling the factory central locking (when you use the key), all it does it activate the solenoid in the drivers door and then the module that controls the central locking (probably in the dash somewhere) thinks that the drivers door has been locked with the key and locks the passenger door.
I don't know if that mad any sense.
Cheers,
Tom.
it looks like they are shock sensors...some cars have those for when someone backs into/opens their door into your car the alarm will sound.....also that speaker thing could be the "blip blip" speaker for arming the alarm.
Tom G - Yup sounds exactly the same to me .. my led was taped to the top of the inside of the drivers side door trim.
im sure it is for an alarm as i noticed my car had a sticker on it saying something about an alarm but its in jap so i could not read the brand name
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
