Brand New Boomerang A2002 Alarm, opened box.
I originally bought 2 of these, one friend who planned to buy changed their mind.. so now I'm selling the spare one.
All optional accessories included. $650 ono.
[email protected]
Details:
The Boomerang A2002 has been around for a couple of years now and is one of the best alarms on the market. Please don't compare this alarm to cheaper imitations. The Boomerang is a class A car alarm with advanced features.
The package comes with all the optional accessories and includes the following;
Usual Items Included
Main Control Module
Remote Control (two way)
Communication Module
Wiring Harness
Battery
User Manual & Labels (stickers)
Additional Items Included
One Way Remote
Shock Sensor (Dual Stage)
Siren (110db)
External Relay
Carrying Case for Two Way Remote
Standard Features
Arming & Disarming
Door open sensing
Shock sensing
Start disable in arming status (Immobilizer)
Auto-rearming Passive arming
Hidden Alarm
Vibration of the Remote Control when the system is triggered
Beep sound & icon flash on the LCD screen when the system is triggered
LCD screen illumination when the system is triggered
Emergency panic alarm
Convenience Features
Automatic door/unlock
Indoor temperature monitoring on the LCD screen
Ignition auto door lock/unlock
Driver Paging
Car finding
Trunk Release
Personal system set-up on the Remote Control
Remote Control's LCD screen illumination
Temporary lock of the Remote Control's button
System override valet
Automatic diagnostics of the system's status
Operation error report
Battery low warning
Programmable personal alarm clock
Passive door lock
Automatic illumination of the dome light when disarming
Five selectable different personal alarm sound tone
Engine Start Features
Remote engine start
Programmable engine start
Cold weather start Turbo timer function
https://www.sau.com.au/forums/topic/51845-boomerang-a2002-remote-start-alarm/
i had a pager alarm with remote start installed for 550, they are pricey things to install.
Hope this helps
If you paid $550 for an install... you got ripped hard.
I have 2 installers who will install the Boomerang for no more than $250.
GTTR34: I will offer you $500 delivered to Sydney..
hehe, dreamin :P
I've already turned down an offer of $500 from a guy in Melb. The price is ONO, but not that low.
does this one have a window winder option?
oh, and you have the same silk bed sheets as me..lol
lol, thanks for sharing that...
The window roll-up module can be added on easily if u want, costs about $50 per side to do. This boomerang alarm kit I'm selling includes an extra relay for add-on modules.
Ok the first person to make an offer over $550 will get the alarm, need cash for more stuff :)
I can get 3 more of these Boomerang A2002 alarms, brand new, with all the extra options, for $570 each.
Email me if interested - [email protected]
Out of curiosity does this alarm have immobilising functions at all? if so how many points?  Curious due to me needing an alarm immobiliser in the not too distant future. :P
The Boomerang A2002 comes standard with a Single point immobiliser.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
