1995 Skyline R33 GTST , Type M ( White) Manual
Series 1.5
This car is in great condition.
Rare Factory Sunroof
Exterior
- Mspec Wing
- Mspec Sideskirts
- Gtr Front Bar
- Veilside Rear Bar
- Sunroof
- Volk Challange Forged Light Weight (17x 8 & 17 x 9)
- Sumitomos all round with 80% tread
- Philips H1 5000k
Interior
- MoMo Apache Steering wheel
- GTR Instrument Cluster
- Trust Gear Knob
- Custom red leather shift and brake boot
- Sparco Pedals
- Panasonic Head Unit
- Alipine rears and front splits
- Us Audio Compe Amp(1200watts)
- 12 inch Pioneer compe sub
Car is clean as it can be
Mods
HKS 2535r Hiflow Ballberring Turbo
Trust Front pipe and Dump pipe
Os Giken Ex Cam
Z32 Afm
Apexi Hiflow Filter
Nismo 555cc Injectors
Bosch 550Bhp Pump
Apexi Power Fc With Hand Controller ( Limited D1 Edition )
HKS Super Dragger Cat back Exhaust 3 "
Big Hiflow 3"cat
Excedy Twin Heavy Duty Clutch
Red Line Bushes
Custom RHK Front Mount
Anodised Red Light weight Intercooler piping
Blitz Turbo Timer Fatt2
Blitz Temp Gauge
Greddy Boost gauge
I think i left out some but thats all for now ,
This car always serviced every 5000ks maybe less
Just had all belts changed , original nissan belts with receipts.
This car has been my baby.
Comes with rwc and rego till nov 2005
Oh yes , car comes with almost all stock parts , including stock Body kits.
Including Stock ECU , injectors , etc etc…
When I got this car it was dead stock. All mods done this year. Turbo not done more then 10000k
Everything is mostly brand new.Need to sell asap , leaving Melbourne.
Asking $24500 ono
Offers???
Or Without Mods (Offers)?
$19500 for standard which still includes rims , intercooler , exhaust system etc etc
https://www.sau.com.au/forums/topic/52009-r33-gtst-type-m-white-240rwkw/
I Have Access To 20k But Id Want The Whole Car With All Mods. Pm If You Are Keen
20k is a little too low , all mods are almost brand new , all done this year.Maybe if u could offer a little higher !Im not asking skyhigh prices as i need to sell asap.
Hi Skynuts nice car, just a couple of quick Q's if you don't mind
Doesn't the 2535 have a T25 flange and the R33 a T3 flange? if so do you have an aftermarket exhuast manifold or just adapters? and what about the dump pipe flange?
How response is the 2535r does the boost start to kick in around 3500, 4500 etc ?
And can you please post some pics of where the temp gauge and boost gauge are mount plus a pic of the center console and the gtr instument cluster.
Hope thats not to much of a strain. :)
Cheers
Dori
i have sent u pm , anyway the turbo is well known for quick responce , thats wat makes it one of the best drift turbos, it starts spooling at 2900 revs. Thats not laggy at all. so yeah ...
Anyone??? Price is ONO !!!!
Dori
You can get a 2535 with a T3 Flange.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
