  • Replies 204
pm sent..
i know this is a stupdi qnz
but wat exactly is the difference between a EL reverse dial and a normal dial?
reverse exactly meanin wat?
lol its simple...
normal = letters and numbers lit up
reverse = background (the white or black bit) is lit up and the numbers aren't
ohhhz lol
thanks TMPTED....
ummm so this does fit a manuel and series 2 skyline rite? coz from the pic that he provided, it looks like an auto car and also from a series 1 too coz the dash/dial from a series 1 and series 2 is slightly different!
i just need to confirm it fits on my car b4 buying
thx
pm'd u as well n waitin for ur reply
cheers
GuiLty
ohhhz lol
thanks TMPTED....
thx
cheers
GuiLty
it doesnt matter if its auto or manual, the only part the new dials cover is the tacho, speedo, and other gauges (which are all lit up blue), everything else is the same.
as for s1 and s2 i'm almost 100% sure it wont make any difference
almost.. lol
cant wait to get mine!!!
Yeah thakns for that TMPTED, I'm pretty sure it will fit both series 1 and series 2 as most ppl have confirmed here, it will also fit non-turbo, all you do is just not install the turbo dial and install the rest, suppose if you want you could put in the turbo gauge dials too, for a bit of rice? lol
Be in quick if you guys still want these dials, I am making the order by WEDNESDAY 13th!!!!!!! Get your money in before then or at least tell me you want a set, I'll be getting a few extras but I can't guarantee everyone a pair. If you can't make the payment date let me know and I'll reserve you one
wait a minute do they look like the one that dazsQ posted in the first message or the ones in the installation guide?? cos they are very different looking dials...
TMPTED
Yeah they do look a bit different. Sorry about that guys.
I assume that the pic dazsQ posted will be accurate for the lit dials.
The only examples I can find anything like this on the web are these from Rezz's diary. The only reason I post this is that you can see no matter what colour they glow at night, they will be white faced in the day. I assume that the ones here will be white faced in daylight.
Can you confirm this daz?
Personally I'm in no matter what the daylight colour :P
Simon
they look like exactly in my first post when lit up, in day time they're white, sorry guys haven't been able to get a pic in daytime form, but they do look good, much better than the ones in blackgtst's post, the red line is red of course and theres 2 shades of blue for the km's and the intervals, dunno if that helps explain it or not
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
