Gday - I need to protect my baby.
Just wondering what people think are the best reasonably priced (ie. not a $2000 cellular tracking system) alarms are?
Also how good are club locks (if they're good which brand is best)?
The alarm should have-
- ability to be turbo timer compatible (I guess this limits it to 3 points of immobilisation?)
- black wires
- some kind of good RF encryption scheme
- a keyfob that is reasonable in size (preferably tiny)
- ability to arm on and off silently
- ability to be louder than legally allowed
- ability to remotely lock/open my car (central locking already installed)
- ability to monitor all doors, boot, bonnet (may need extra button)
- ability to monitor window breaking
- ability to monitor tilt (tow away protection)
- ability to have some adjustment so I can turn the sensitivity down
- a light that flashes
Oh and it would be cool if it could wind down my windows for me :)
Any other criteria you guys think would be useful/necessary would be greatly appreciated!
https://www.sau.com.au/forums/topic/52230-protecting-your-baby-from-theft/
  • Replies 58
On my very first car I had a crappy one installed at strathos for like $350 and it did more than half of that.
Silent arm, reasonable keyfob, tilt sensor (that never worked but hey), 4 point immob, ability to be louder than legal, monitored all windows/doors/boot/bonnet, screamed when battery unplugged, etc
I thought those features were standard on most alarms??
You could have all of that and more...it only takes a few seconds to have your car ****ed with, no alarm I know of can defend against a molotov c0cktail or a paving slab.
Better still get a mongoose immobiliser...even if you've got the button *IT* decides when you can or can't start your car grrr!
I picked up a unit from AUTOBARN and fitted it myself. I didn't get the window lift option, or tilt option - but it had everything else you listed. I think it cost me ~$150.00 The insructions make it a pretty easy job (if you have a test pencil/multimeter). I did not like the tought of having someone else know how my alarm was wired and where all the wires went....
That's cheap DAN00H - I know what you mean about the wiring and knowing where it is.
2BNVS - Thanks I will look into the that model.
Thanks guys - does anyone else have anything else for me to look into ? I'm going to do it this arvo I think.
Well I just got quoted a top-of-line-ish alarm with pressure, tilt sensors and the majority of the stuff I wanted except :
$450-500 installed. Windows would be a little extra.
Same guy quoted me QT installed with one year for $1700 - I'm tempted to go with that as a peice of mind thing.
- black wires
Oh and it would be cool if it could wind down my windows for me :(
how about a tracker ? $990 if you can fit it yourself and $1290 if you want it fitted in , no annual fees . you will know where your car is all the time the minute someone opens the door you will know , you will know if someone started it or if the car is moving , speed , direction and best of all you can immobilise it from any phone at any time .
with an alarm you will not know anything , a siren will go on for 1 minute thats it , cut the siren and its silent .
alarms are old technology soon every car will have a tracker ...
why do you want to have silent arming and disarming?
then you wouldnt be able to tell if its armed without looking at the light on the dash.
When getting in and out of the car without wanting to draw attention to it - getting home late etc. You can tell it's armed by looking at the hazard lights/listening to the central locking lock.
also, my alarm beeps twice when disarmed and then twice more if the alarm has gone off. that way you can check your car out for any damage etc.
I think that's a great idea! Which alarm is that?
Can you explain to me how this works please? Unfortunately I don't drive my car to work so it would be difficult to do anything about it if it went off :(
true true..
does any one have a handbrake lock? Locks the handbrake up and locks into gear. Probably only any good if u could lock it into 5th. Nonetheless a good visual deterant and another couple of seconds they'll need to spend before they get away with your baby.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
