This is not my car but I do know it and know that it's a true "wolf in sheep's clothing". I also know that it's a clean and VERY fast car !!! Anyway, here's the lowdown :)
Silver 1996 R33 Skyline GT-R Vspec
Built to look stock standard from the outside, but every aspect of the car has been designed to handle the 800 HP+ performance every day with total reliability.
Engine:
- Huge bar & plate intercooler + plumbing.
- 2 x GFB blow-off valves.
- Super-strong bottom end inc. crank, rods, forged pistons, Nismo bearings, rod bolts.
- Nismo oil & water pumps.
- 2 x Garret 450HP ball-bearing turbos.
- HKS gaskets used throughout + HKS S/S head gasket.
- Tomei cams and vernier cam gears.
- Hand ported, flowbenched head with O/S sodium filled valves and mirror polished ports.
- Extrusion honed exhaust and intake manifolds.
- Everything match-ported.
- All heat-loaded parts HPC coated.
- All load-bearing parts cryogenically treated.
- Oil/air separator.
- Cusco catch can
- Braided lines.
- Dual 3" S/Steel exhaust from turbos to tips.
- Large oil-cooler w/ braided lines.
- Trust/GReddy sump baffles.
- Computer: Apexi Power-FC PRO with 3-bar MAP sensors and hand controller.
- Boost Control: Apexi AVC-R.
- All machining, balancing and assembly to blueprint or better specifications.
- Professionally assembled and tuned.
- On the dyno made 402kw at approx. 6000rpm, then produced wheelspin after that. Conservative power estimate: 820 flywheel HP
Fuel System:
- Sard 740cc injectors.
- Sard rising rate fuel press. regulator.
- Custom fuel rail with press. equalisation.
- Nismo in-tank primary fuel pump.
- Bosch Motorsport external Fuel pump.
- Custom swirl-pot.
- All fittings, lines, pumps and swirl-pot hidden.
Drivetrain:
- OS Giken twin-plate clutch.
- 35 degree straight-cut gear-set.
- Larger diameter shafts all round.
- Nismo synchro set.
- All parts cryogenically treated.
- Strengthened and tightened diffs.
- 10-plate wet clutch upgrade for 4WD system.
- Stronger driveshafts and CV joints.
Other:
- Nismo suspension all round.
- Massive Porche GT-3RS brakes w/competition pads.
- Nolathane bushings.
- Camber & castor modifications.
- Flaken AZENIS 255/40 tyres.
- Nismo 320kph instrument cluster.
- Nismo center-stack gauges.
- Nismo short-shifter.
- Power-FC hand controller.
- G-Reddy exhaust temp gauge.
- Apexi AVC-R controller.
- Fully automated turbo timer.
- 4-stage programmable shift light.
- Momo steering wheel w/ HICAS compatible boss kit.
- Pioneer stereo w/ 2 amps, splits all round and Pioneer sub.
Rego to Jan 05
Price: $75,000 or near offer.
NO TIME WASTERS PLEASE AND A SECURITY DEPOSIT WILL BE REQUIRED BEFORE TEST DRIVE ALLOWED !!
Contact: Mick on 0410-558-711
https://www.sau.com.au/forums/topic/52242-96-r33-gt-r-v-spec-modified/
Sad but true pete ! I just don't want to be around when the sale takes place. I hate seeing a grown man cry......god knows, I couldn't sell it if I owned it. Prol sell a kidney first !!!
  • 3 weeks later...
- On the dyno made 402kw at approx. 6000rpm, then produced wheelspin after that. Conservative power estimate: 820 flywheel HP( your ad)
can you just tell me something how did you come to the conclusion it makes 800flywheel horsepower when i make 450awkwand i was told i only make about 650 fly wheel horsepower. and i didnt get wheelspin
If your pulling 450 kw @ all 4 wheels thats around 600hp @ all 4 wheels so you would be pushing a bit more then 650 hp at the flywheel at a very rough guess you would be some where around the 750-800 hp mark unless you were on a very happy dyno
hehe "happy dyno"!
450kw equals 603hp.....conversion is something like 1.34. So i'd say more than 650hp at the fly for you wreckedhead.
Impressive power either way...for both cars
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
