Hi Dave, what you are describing is totally normal, unless I have missed something. At idle the throttle is closed, the engine is running (sucking) so there is vacuum between the inlet valve and the throttle body. If there wasn't vacuum (sucking) then the engine wouldn't get any air in, so it wouldn't run.
Hope that answered your question:cheers:
Aren't they the T28 ? (Same as GTST turbo. . .?) If they are, they're generally good to run 14psi occasionally, but I wouldn't drive my GTSt any higher than .85 bar (roughly 10 - 11psi) constantly.
So when I get the stag (2 weeks) I put my AVCR in her and set setting A to 0.8 bar (normal driving), setting B to 0.9 bar (drag) :rofl:
On thing I noticed on mine when the boost was up to 12psi was that it was damn loud !! I'm still running the stock airbox with a highflow panel filter, oh, and the sound deadening wading in the airbox has been removed too.
But the difference between 5psi (stock) and 12psi is massive... Anyone else notice this ?
I'd rather it not be noisey, it sounds like a pod filter when it comes on boost...
J
I might let up the boost a little once I have the front mount and dump pipe on the car, that way in my opinion Ill be pushing the turbo just as hard as I am at the moment, with less restrictions such as full exhaust and front mount intercooler (well at least the piping change) you can safely say that running say 11psi as opposed to 7psi or so with standard gear you'll be pushing the turbo just the same..
As for increase in sound, what sound deadening stuff in the airbox are you talking about? Nothing I could see there? Mine isn't insanely loud, defanatly not as loud as a friends r34 with just a pod filter.. Certainly audible but hard to hear with windows up and a little stereo going.. Its not a whining noise is it?
J
I raised the boost on my r33 to about 10psi, and at the same time removed the sound deadening padding in my air box, and it is LOUD. I remeber going for the first drive and thinking to myself "did i put that panel filter back properly?" :wassup:
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
