EDIT:
Christian has made the change to CafePress to avoid the ten unit minimum orders associated with tshirrttext (so that orders can now be processed immediately and not queued). As such, the below orders have been cancelled. The replacement range of merchandise can be viewed at: www.cafepress.com.au/sau
There is a small range of embroided SAU merchandise still remaining, including hats, beanies and polo t-shirts. I will post more details later tonight if any of you are keen on picking up the last of the old stock.
To everyone who has purchased Skylines Australia merchandise through tshirttext, thank-you for your support over the past 18 months. icon14.gif
Please be aware that all merchandise orders for standard t-shirts, female fit t-shirts, long sleeve t-shirts, hooded jumpers and polo t-shirts are now being queued and processed as orders of ten garments.
Once you have placed an order, keep an eye on this thread. It will be updated daily. Orders can be cancelled at any time - but keep in mind that this will be to the detriment of other buyers. Payment is not required until your order is processed.
Order Progress:
1. Ghostrider, black SAU polo t-shirt.
2. chris_smith, black SAU polo t-shirt.
3. Merm-R, black SAU polo t-shirt.
4. 95GTST, black SAU hooded jumper.
5. Rhinorebel, white standard t-shirt.
6.
7.
8.
9.
10.
Place an order.
Tight-fit beanies and flex-fit hats are available to purchase at any time through the SAU Merchandise Shop.
If you have any comments or questions, please e-mail: [email protected]
https://www.sau.com.au/forums/topic/52730-merchandise-announcement/
  • 2 months later...
  • 1 month later...
Hey,
i got a 1996 Daewoo Cielo and i want to add to the mods. I already have a talon Front spoiler and side skirts the rear will be completed in the next few months. And i have a T - Wing i picked up cheap out of the sunday times. What can i do to the engine to give it some more go, on a tight budget? :wassup:
Lets make this thing deadly!!!! :ghost:
  • 3 months later...
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
