hey guys i found a r32 gtr 5 speed for sale and i was wondering whether its easier to use the 33 or 32 box and whether they are the same ????
also does the front tailshaft from the auto fit the gtr 5 speed by any chance or will i need a gtr one?
is the attessa 4wd stuff run by a computer??? or hydraulics? or what? and if its run by ecu, is it seperate to the engine ecu???
sorry for the billion q's again but i wanna make sure i buy the right stuff 1st time round
will i need to get a gtr rear tailshaft as well i presume????
i need to sort out what i need and what i dont need :D
thanks again
Brad :rofl:
The R33 is rumoured to be a bit better but I haven't seen it.
I suspect it is the same, because the transfer case is pretty much the same
Yes
or hydraulics?
Yes
Yes
The engine ecu talks to the ATESSA ecu which uses hydraulics to change the preload on the clutch pack which alters the amount of drive to the front wheels.
Again I think the auto and manual are the same
I don't think you can do/know/buy EVERYTHING before you start, I suggest you get the major/known items and just get on with it.
whats the diff ratio on the stagea autos????
Sorry I don't know that, but I suspect it will be different. You need to have both diff ratios the same. So you either use 2 X GTR diffs or 2 X Stagea diffs.
is the diff good enough to handle the 26 conversion???
I would say so.
is it the same as a gtr diff???
Not sure what this question means, ratios as per above. Centre (as in LSD) unlikely to be the same but I don't think it matters.
Personally I would use as little GTR stuff as I could, then if I find a deficiency later on I would upgrade that part. If you just go heavily into GTR stuff everywhere, you will end up spending more money than you need to. The best way, if you really want to transfer everything would be to buy an accident damaged R33GTR and swap over all the parts, that would be cheaper than buying bits one by one.
Regardless of methods, if you change it completely (as in every single part) it would have been cheaper to buy a 260RS. The best way is to do the important/essential stuff and ignore the "nice to have stuff". There is a young NZ guy on the forum whose father has done an RB26 transplant into an N/A manual Stagea, he may be worthwhile talking to.
Hope that helps :rofl:
Have done the conversion.
Tailshaft - different
I used a 32 gear box but the 33 box is exactly he same only the clutch is different and the mounting of the slave cylinder on the bell housing.
front tailshaft is the same.
four wheel drive is in the ECU and works fine in my car. ( about to change this to power fc )
There is alot of mucking around to convert but well worth the exercise.
If you have any more questions let me know and I'll try and help.
Cheers
Gary
4wd/abs are in the same computer, down the back of the car
the inputs it needs are same as any other atessa ecu (refer 32 gtr workshop manual)
btw sydney kid, im not _that_ young (21 ;), i've got a 32 gtr myself :)
the 260rs uses a assisted clutch (needs firewall mods), but you can run unassisted no problem, we run a hks triple plate, the pedal is heavy, but not a killer
we prefer the 32 style box because of the clutch setup
so if you want to go for the assisted clutch the firewall needs to be modified but if you fit a 32/33 gtr box you dont need to cut into the firewall? (except for the clutch pedal i guess.
how hard is it to relocate the handbrake?
there were some firewall mods. apparently if you don't use the power assist, the clutch can be a bit of a pig ie. gear selection with the clutch not disengaging properly.
The hand brake is the bastard thing. all the brackets from the rs260 were used on mine and rs 260 centre console, and i still haven't got the plastic foot rest thingie to replace the auto one.
Cheers
Gary
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
