if any one has the 100v 2 pin plug in there stagea ...hullo prank...i have this interesting piece of kit that came in the back of the 260 but i think the guy has taken inverter with him
its a kenwood super woofer...looks like a smoke machine or some kind of rocket launcher
3 switches on back ..phase(norm or rev),omni position,turnover
3 lights ,60/90/120 hz
volume dial
on the front just says 100v 35w 50-60hz
is a heavy mofo ..really don`t know what it is worth ...can anyone tell me??
https://www.sau.com.au/forums/topic/52950-100v-inverter/
Jake, that looks a lot (if not exactly) like a HOME subwoofer that Kenwood released many moons ago, IIRC...
Maybe it's an added bonus from the last owner when the car was sold and sent from Japan!?!?!
Couldn't tell you what it was worth, though, sorry. Maybe you could get the model/part number off it and Google it, and then have a look on e-bay as well.
Nick T.
https://www.sau.com.au/forums/topic/52950-100v-inverter/#findComment-1041462
Nick T.
yeah its a sinister looking piece of gear...i`m thinking i could get good money if i listed it on e-bay IRAQ.....with the right ammo it could take out tank...
https://www.sau.com.au/forums/topic/52950-100v-inverter/#findComment-1043076
i have option catalog ..DAYZ...piture of rear power point in console with laptop /keyboard plugged in to it ..scanner has issues so cannot post pic atm
i know where there is a sic subwoofer that will run of it and i suppose any jap 100v equipment
will also
https://www.sau.com.au/forums/topic/52950-100v-inverter/#findComment-1044081
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
