  • Replies 43
Huge or Extream would be good words to use for LAG when bolted on a RB26DETT but when it comes on boost it does rip you back in your seat unlike it's little brothers. Great on fuel as a day to day driver as you hardly get to use the last 3K of your RPM's going to work and what not.
https://www.sau.com.au/forums/topic/53155-t78-drivability/#findComment-1044626
RTF you've probably hit it on the head lol. Sounds like the turbo won't kick in until late 4k to early 5k rpm if I am lucky so that should be a fairly fuel saving LOL.
One question though, does twins necessarily means it will come on boost quickly? I am looking at a pair of GT3071R (http://www.atpturbo.com/) GCG is their reseller here in Australia.
https://www.sau.com.au/forums/topic/53155-t78-drivability/#findComment-1044708
SK always anaylising that step further..
If you want the right answer, first you have to have the right questions. Then you have to have the data. Without data you are guessing, and I try to never guess.:rofl:
https://www.sau.com.au/forums/topic/53155-t78-drivability/#findComment-1044837
I have a turbonetics t66 with a 1.0 p trim wheel on the exhuast side ( think very similar to a T78 ) on my 2.6ltr wrx and it starts to pull at 4500 rpm. but it comes on hard picks up acouple of hundred h.p in 500rpm. i supose it depends on what you want to use the car for. I would like to put a set of twins on my gtr but the cost is a bit much. go the big singles they rock.
https://www.sau.com.au/forums/topic/53155-t78-drivability/#findComment-1044843
What spec of T78?
What other mods?
What do you use the car for?
T78-17.0kmg2 (or whatever that is)
Actually there's not much mods left once the stock turbo is taken off besides the fuel system been looked after. At the same time fitting the T78 I'll be dropping in a set of Tomei Poncam (260/260, lift 9.15) and spocket and a PowerFC.
What the car for? Bit of track, bit of drag just a bit of everything so it's gotta be an all-rounder or the least compromise of each the possible.
https://www.sau.com.au/forums/topic/53155-t78-drivability/#findComment-1045036
dude,
with the 17cm^2 exhaust housing, it would not be a very user friendly street car.
you'd be looking at fullboost at about 5000-5500rpm if not later.
if possible, fit a smaller T78 housing or get a garrett A/R .82 (T04) adapted/machined to suit and it will be heaps better for the street and the track.
or better still, i fu haven't bought it yet and are looking to go single, the new Garrett GT35 (A/R .82 exhaust housing) would be awesome. nice spool up and heaps of air-flow.
https://www.sau.com.au/forums/topic/53155-t78-drivability/#findComment-1045126
A T78 on a 2.6 litre is not good for any type of circuit work. Have a look at the quick Japanese circuit Skylines and they run around the 650 bhp mark. Bottom line, there are more suitable turbos for your requirements.
Hope that helps :rolleyes:
https://www.sau.com.au/forums/topic/53155-t78-drivability/#findComment-1046424
LOL...i was watching an Option DVD and there was footage of workshop cars going head to head, try WRX with TD06-25G, Jun R33 with T88! Plenty of these Jap cars used big ass singles, then again there were GTRS using 2530s as well. Interesting thing was pn the Apexi Drift RX7 i noticed some nitrous solenoids in the engine bay so i wouldnt go trusting too much of what you see going on in Japanese engine bays.
https://www.sau.com.au/forums/topic/53155-t78-drivability/#findComment-1046458
Hi Roy, we could go around on this one all day. The Jun GTR isn't 2.6 litres, the works HKS driver uses N1's on his R34 GTR for around 600 bhp. He could have a T51 if he wanted. Plenty of people have tried, but as far as I know the GTR lap record at Tsukuba is still held by the Mines GTR and it doesn't have a T88 or a T78 or more than 650 bhp. You might get more power from a monster turbo, but the driveablity goes out the window and as you know lap times are more about the total engine package than outright power. :rolleyes:
https://www.sau.com.au/forums/topic/53155-t78-drivability/#findComment-1046499
Aren't the big singles that are being discussed here plain bearing, as opposed to the HKS GT-series and the N1 turbos which are all ball bearing, afaik? Wouldn't that mean that the drivability/torque delivery is more to do with turbo technology than being twin vs. single?
https://www.sau.com.au/forums/topic/53155-t78-drivability/#findComment-1046521
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
