gtr trottle bodys $250 the set
gtr std pleunm $400
gtr transfer case 33 and 32 $300
gtr33 rods in perfect condition $300 the lot
gtr33 std pistons in very good condition $250 the lot
toda racing cams 276/10.2 both as new done 3000kms only, gtr, my car made 809hp@ wheels with these cams asking $900 the lot
gtr33 balancer as new done 2000kms, perfect for a rebuild motor, $200
gtr greddy (trust) pulley kit as new $500
hks t51r KAI turbo, all been modifyed by hks with SPL internals, done 3000kms only, full chrome housing, rated for 1000hp. $3500
hks headgasket 1.6mm, rb26, brand new, $420
gtr33 alloy bonnet $600
gtr33 mirrors $150pair
original gtr33 side skirts $250pair
[email protected]
for pics email me please.
https://www.sau.com.au/forums/topic/53255-parts-left-over-to-suit-gtrgtst/
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
