  • Replies 133
Yeah I'm thinking of putting a new computer in it coz it's not street friendly at this stage. With aircon it always stalls and makes me look like a bad driver so I think i will have to fix that.
I'm not sure if I will be taking it to Steve as yet. Just trying to work out what is the best option at this stage then get some money together first.
Will you be cruising on Friday night with the rest of us?
Originally posted by HUSTLR
LOL:lol: :lol:
doh!!!
Marvin- i heard your putting a new computer in it
Can't make it Friday night-
I was hoping people would turn up on saturday night also
Steve's working on Jap cars like there's no tommorrow lol:lol:
His got 2 import dealers sending there cars to him- plus i'm telling my friends- His always too busy!!!!
You guys are a crack up! :lol:
So you are cruising on Sat then?
If Steve is around Sat day or evening I might come around and see him. Yeah he has alot on his plate ;)
He wants to do a crazy setup for my car- Convert to a twin-turbo - T76- 3L bottom end blah blah blah blah lol:lol: :lol:
Minh - doesn't believe me that he worked on DR CRX's engine setup when he first came out- lol:lol:
Saturday night we hang out at Burger King, corner Cabra Rd and Cumb. Hwy after 10pm and decide where to go runz or cruize-
so what did you do? Who wa sthere?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
