Hello.
I just got my Stagea last week and I'm rapt with it. I've put a turbo back 3" exhaust on, an Apexi Power Intake and a GFB BOV. I just installed an RSM today.
I have a weird problem. It seems that when I put the foot down and then come to a complete stop the engine will die. It happened twice today when I pulled out of a carpark put the foot down to go up a hill then stop at the top for a roundabout. It's an auto. Has anyone else experienced this? Why is it so? My car has only done 34000ks.
Please help.
Thanks.
Zane.
https://www.sau.com.au/forums/topic/53534-help-my-stagey-stalls/
Hi Zane, you can't have a open to atmosphere BOV. The ECU knows how much air goes into the engine via the AFM, so it squirts in the right amount of fuel for that air. But the BOV lets a whole pile of that air escape, so the ECU squirts in too much fuel when the BOV is open. Bingo, too rich a mixture and the engine stalls. Get a plumb back BOV and all will be well again. I have never found anything wrong with the standard BOV, so I have and will not be changing it on my Stagea.
Hope that helps:cheers:
My BOV is a Hybrid valve. If I turn it further towards plumb back this should fix it aswell?
Also the other day when it stalled I put it into P so I could start it again but my car was still rolling a bit. It started making this shocking noise. Kinda like when you do your diff. I stopped and put it back into D and it went O.K. Would I have done any major damage? Feckin' hope not.
I had a feeling that may have been what it was. If I buy an SAFC-2 that should fix my problems yeah?
Thanks for the help
Nope, the SAFC has no ability to adjust zero throttle richness.:P
Yep around 60% or more plumb back will help, assuming it is physically plumbed back of couse.
Oooops, auto gearboxes have a lock on the output shaft so that when you put them into Park the car doesn't roll. Hopefully you didn't break off the locking pin. Easy to check, just put it in Park on hill, when you are stopped of course, and make sure it doesn't roll.
When moving, Neutral is the place to restart the engine.
Thanks for your help mate. My mechanic just told me the same thing. I have just had a boost gauge installed. I noticed that boost is around 5psi then goes up to 10psi at around 4500 revs for a little while then it drops back to 5psi until redline. Is this normal?
I think the SAFC II model has the feature to adjust the fuelling mix as it returns to idle. This is to stop the overfueling that happens and stablize the idle. The earlier editions didn't have this feature. It must have been a feature added purely for the addition of externally venting BOV's.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
