I have a stock RB20det engine that has a slight knock in the top end somewhere, louder when the engine is cold. Was told by APC here in Brissy that it sounds like a sloppy gudgeon pin. Motor was running fine before I took it out for replacement. Engine had 60,000km when imported and I have driven it around for 7 months. Turbo is in excellent condition, driven daily at 9psi. Boosted to 14psi at willowbank and ran 13.3sec at 108mph in 180sx. Complete motor with all accessories except AFM $650. Will separate.
also have a turbo that needs rebuild but has no play. Not sure what it is. Was told it is a high flow RB20 with steel wheels, but have also been told it could be a VG30 turbo???? Pics of turbo below next to standard RB20 exhaust housing. $300
Have yellow injectors, not sure what they flow. They are off a toyota engine so you will need an after market computer to run em, but they are a direct fit. $50
Following bits are off a R32 halfcut that I have. (94.000kms)
RB20 auto g/box with flywheel $100
Std auto ECU $150
Complete loom $150
Std intercooler $40
R32 Brake booster $50
R32 cross member (suit RB in S13 conv) $100
R32 KYB front shocks $200/pair
R32 dash and inst. cluster $200
Stock dump pipe and front pipe $50
Air Con complete (looks new) $100
After market s/wheel $50
I am here daily so PM or msg me for info, no emails as my email is f'ed.
Steve
0411 206 780 Brisbane
I'll give you $100 for just the head if the valves an so forth are in good nick. I have no need for manifold, turbo, Plenum rocker covers ect. I can pick up on the weekend.
Ok mate, I have a second parts engine, give me a call when you wanna come down and I'll give you my addy.
Steve
r the kyb shocks with springs?
do u hagve coil packs in good working order?
does the steery have a boss kit?
cheers
Hows it goin mate? Yep the shocks have springs, they are KYB and are light blue with 'New SR SPECIAL' on em. I have a set of coil packs, motor hasnt run for 9mnths and I havnt had em tested. Motor ran fine but had big end noise. They are not off the motor I have for sale. Make me an offer on em.... Not sure what the steering wheel is????? May be a stocko. What does the stocky wheels logo look like in the centre?
Regards
Steve 0411 206 780
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
