NISMO,
If I was to guess at it I would say that the alternator bearings are on the way out!!(these can sometimes make the exact same sound that you describe so I would check this first) But to check it you would have to remove/loosen the belt to see how easily the alternator spins to make sure!
MEGA
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-85169
hey guys i got a bit of the same thing with my car, when it is first turned on its has a whining noise, this goes away after about 4 mins.
and what bearing do you think will be fked if when the clutch is out there is a loud noise but when the clutch is in it stops ?? ideas anyone
thanks
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-87643
There was a thread on this a while ago, but no resolution.
I have the same problem.... When its cold, you start the car, and you get a screech (intensity of sound depends on how cold it is), and it will last about 1 - 2 seconds.
I've had this prob for over 6 months now, and I have no idea what it is. As it only does it when i start the car, and the outside ambient temeperature is low, AND it only lasts about 1 second, I haven't bothered to fix it!
And no it's not the fan belts,
Doubt it is the alternator bearings, as it would do it more consistently...
Can anyone else that has this problem, please tell us if you also have a squeeky clutch! As in does your clutch squeek sometimes when you depress the pedal?
Zahos
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-88808
have a read through this thread adam
http://forums.skylinesdownunder.co.nz/show...=&threadid=7186
I'm just trying to figure out if the 2 probs are related....
Anyone else that has the noisy start up problem hav a squeaky clutch? Even if you have one prob, and not the other, please tell us, and how long yoou've had the problem.
Thanks
George
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-88947
bugger everyone has the same thing here
we need to have a skyline meet lol "maintanence meet"
we can all do our bearings and squeaks at the same time :)
like a dyno day :)
might aget a quote on getting the throwout bearing...or even get someone to look at it and tell me what they recon it is
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-88973
Zahos,
I have a auto(Not for long though) GTS4 and I have experienced the same sound on start up (only twice so these would have been cold outside and that the car hadn't been started for one week) so I don't think that the start up noise is related to the manual gearbox.
It seemed to come from the front of the car where the alternator is located?
It also happened after I fitted a new fuel filter and had to clean the engine bay again I thought that a unsealed bearing had got a bit damp because I only cleaned the drivers side of the engine bay.
I can't actually diagnose the problem because it has only happened to me a few times and is inconsistent enough for me to leave it alone until I put in rb26.
MEGA
where is NISMO?(the one who started this thread)
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-89363
Thanks for that Mega!
So now I'm left with no clues as to what it could be! I would think that if it were bearings that it would do it more consistently? A friend had the bearings go on his air-con, and that made bad noise consistently, wouldn't the bearings off any component working off the fan belts do the same thing if they were buggered?
Anyhow, summer is coming so I guess I wont have to worry about this one for a while!
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-89582
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
