hi guys :)
ok, i have an OS twin plate clutch, and i was wandering about something..
whats rate on that? how much could it handle..
also, and this is the important Q :
a while ago i heard that u can rebuild ur OS clutch by Exedy!
is that true?? iive been trying to remember where i heard that but no use :D
any idea???
https://www.sau.com.au/forums/topic/53819-os-exedy/
mate there is an OS dealer in Aus too. www.otomoto.com.au
Rebuilding your OS clutch with exedy bits will not give you a new OS clutch. Just like rebuilding your HKS turbo with Garret parts does not = a new HKS turbo. If (when) I need to rebuild my OS twin plate, I will buy the new OS parts for it. no stuffing around.
Richard
https://www.sau.com.au/forums/topic/53819-os-exedy/#findComment-1057028
hi guys :D
1.whats rate on that?
2.how much could it handle[/b]..
3. a while ago i heard that u can rebuild ur OS clutch by Exedy!
is that true??
any idea???
1. there are two types of OS Giken twin plates, one is rated at 550 bhp and the other 700 bhp in a GTR (4wd and extra weight) so slightly more for GTST (2wd and less weight).
2. lots, we have had 650 bhp for 2 years in a circuit race GTR using the 550 bhp OS twin plate.
3. my local clutch shop put new linings on the OS Giken clutch plates, no problems.
Hope that helps
https://www.sau.com.au/forums/topic/53819-os-exedy/#findComment-1057767
Hey SK, how did they reattach the clutch plates, and what material?
No one down here has the 1mm thick plates.. or know how to attach it?
The OS Giken clutch linings are bonded onto the disk on the road (lower power rating) spec multi plates, they also have coil springs for taking up the shock loading. The race (higher power rating) specs have no coil springs. The splined centre is rivetted to the disks. So the process is to drill out the rivets, keep the spined centres and replace the disk and linings with new parts. The equivalent Daikin parts fit pretty well.
Hope that helps:cheers:
https://www.sau.com.au/forums/topic/53819-os-exedy/#findComment-1058651
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
