quickfit are way overpriced from what i have experianced if any in canberra i would stay clear of it would be them their prices were at least 10 - 15% higher than the other places i was geting quotes from.
do what i do though ring up a couple of places get their best price then just keep rining them back saying this place said they will do it for this how much will you do it for :P works wonders i got about 25% off the initial cost i quoted from one place :D
Transtate in belconnen near project lighting, they have tyres imported from japan cant remember the name but they are cheap and really good in all conditions, mine were 265, 45, 18" cost me like $250 each.
Did the ring around today and was disgusted with some of the prices from some merchants I will not mention.
More than double the price of other retailers.
Anyone happen to have seen better prices for these in a 225/45/17
Falken ST1152 - $230
Dunlop SP9000 - $239
i need 2more fronts now, dont really want to pay more than $200 each though
so $180 for the hankooks sound good. i want super low profile tyres though, dont they cost more? seems odd though as there is less rubber on them.
I could run upto 245 apparently, however i don't think I want to as any significant change in the rolling diameter plays havoc with the TCS.
Yeah i saw that price from Tempe on their website but got quoted an extra $10 when i rang up - a little worrying to me.
Thanks for the suggestions though.
ok back from ed's, he's ordered them in for me, they are i think 245/45/17's (not 100% sure) there were quite a few to chose from. the ones im getting are $210 each (will probably do them cheaper on tuesday when they arrive) and as far as he's concerned are good tyres and will do a very good job, so i guess all in all im happy, i could have got ones for $190 but these seemed slightly better and they will wear better for me anyway.
Do you know what brand/model they are?
sigh, no. i should have asked hey? i will find out for you and let you know, and once they are on i will give some feedback as to my thoughts/oppinion on them.
as i said ed seems to like them, and i trust him implicitly, so all should be good.
on the topic of tyres, anyone know what the usual price for a set of tyres for 18 x 8/7.5 rims? i'm tossing up between 18's and 17's for the stagea, and if rubber for 18's is much more then stuff it
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
