Hi,
I'm considering a job in Japan for next year, and wondering what's involved in bringing a car back with me to Australia that I would buy over there?
I'm aware that I'd need to have proof of ownership for 12 months or greater, but I'm unsure of how the process differs from the Low Volume Import scheme. Apart from not needing the same type of compliance as a Low Volume import, what other differences are there?
Would the car need to be registered and used, or could it be bought at the beginning of the year, warehoused, and then import as a private import?
Thanks for any info you can provide.
-wm
https://www.sau.com.au/forums/topic/5394-private-import/
I have heard rumours that if you have owned the car for over 12 months living in Japan it can be bought over as a private import and thus does not have t comply with ADR's as not part of the low volume import category.
This would be quite cool indeed.
:uh-huh:
https://www.sau.com.au/forums/topic/5394-private-import/#findComment-82377
Guest GR33DyMANGO
so BY BY you're saying u dont have to pay for compliance with costs a few grand and is increasing in march 2003 to something rediculous so its too costly to import???
that would be so awesome if thats what u mean. i might be heading off to hong kong in about a year to work. hmmm.. maybe i could have an r35 in a few years... hehee....
https://www.sau.com.au/forums/topic/5394-private-import/#findComment-82398
to be eligible for personal import you need to supply the following..... Parking permit,registration documents in your name,Insurance documents,passport(stating that you have been in a particular country for over 12mnths).Once an impot approval has been issued,you can send the car.Once it arrives the car will need to be checked by an engineer.Seatbelts will need to be changed if they dont have an e marking,child restraints be fitted,unleaded filler neck and some other stuff depending on the model of the vehicle.In regards to a car from hk...id forget about it as the tax payable on buying a car and owning it for a year in hk would out way the cost of just buying it straight from japan...especially a model such as a new 2 door skyline which will be eligible under the new sevs scheme anyway.....hope this helps
https://www.sau.com.au/forums/topic/5394-private-import/#findComment-82457
yep....the same duty applies...although i beleive there is a depreciation form that you can fill out but its not woth the hassle...unless you owned the car for 5 years..then the purchase price would be dearer than the current market price.I got pics but how do you post them to apare on the screen and not as an attachement???
https://www.sau.com.au/forums/topic/5394-private-import/#findComment-82501
Yo Waxman, I'm considering going to Japan next year aswell.....
You gonna be teaching english over there or doing something else?
Keep us all informed of how everything pans out for you.......I'm sure that if you go over you'll have no spare time because you'll be too busy finding cheap parts for everyone here! :lol:
https://www.sau.com.au/forums/topic/5394-private-import/#findComment-82551
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
