ok, ok, i posted this one in another section, but im particularly interested in knowing if anyone in perth has one of these, and there's no real specific "electronics" section.......sorry!!!!
gday guys,
i was checking out new alarm systems, came across this unit on this website http://www.incaroption.com.au/
they're a sydney dealer importer/dealer for the boomerang alarm system.
they have this one listed as well -
"Steal Shield (SS-900) Remote Engine Starter, Immobilizer, Shock sensor, in built Turbo timer, Boot release output, Door bonnet boot protection, code hopping Technology"
for $475 (comparred to the $995 for the boomerang).
i've seen the dodgy looking ones on ebay claiming to do all this, but you'd assume that these guys would have some sort of cred??
anyone know anything about this unit?? anyone have one/know a mate who has one??
is it black wired and asa/insurance compliant? i know its approved in nz, but not sure how their regs match up to ours here.
have searched the forums, didnt turn anything up.
would prefer not to have to either fork out a grand for the boomerang, or risk some dodgy ebay imported unit, and to me, 475 is a pretty decent price, by the time you go and buy a separate alarm kit and turbo timer.
anyone got any first-hand info on it here in australia??
https://www.sau.com.au/forums/topic/53960-stealshield-ss900-car-alarm/
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
