These look like Ferrari F40 rims and would look great on GTS/GTR 32,33. Unfortunately i only have 3 of em. So basically this is for ppl who already have these rims already but broke one of em (dats what happend to me) hehehe or anybody has one for sale, i would gladly buy one off!!!
Heres a pic
https://www.sau.com.au/forums/topic/53997-for-sale-17-speedline-rims/
what size's + offsets are they? and what price are you after? a pair of rims would be nice to throw some cheap rubber on the back for a bit of "fun".....depends on the price though :)
I will go check out the offset but i'm sure it'll fit R33 GTST. So basically all up $500 for:-
3X17" Speedline rims with 90% threads 245/45
1X17" Spare tires 245/45
Definitely worth it for spare drift mags
Offset is usually a number written on the back of the mag on one of the spokes any number ranging from 15->45 usually for a skyline gtr from 15-32+ offset
the width of the rim is usually written as 17 x 8JJ or 17 X 9JJ somewhere on the back as well.
hope i was helpful g'luck wif the sale
my 2cents
Thank you very much GTshortie! I will go home and check
my 2cents
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
