These look like Ferrari F40 rims and would look great on GTS/GTR 32,33. Unfortunately i only have 3 of em. So basically this is for ppl who already have these rims already but broke one of em (dats what happend to me) hehehe or anybody has one for sale, i would gladly buy one off!!!
Heres a pic
https://www.sau.com.au/forums/topic/53997-for-sale-17-speedline-rims/
what size's + offsets are they? and what price are you after? a pair of rims would be nice to throw some cheap rubber on the back for a bit of "fun".....depends on the price though :)
I will go check out the offset but i'm sure it'll fit R33 GTST. So basically all up $500 for:-
3X17" Speedline rims with 90% threads 245/45
1X17" Spare tires 245/45
Definitely worth it for spare drift mags
Offset is usually a number written on the back of the mag on one of the spokes any number ranging from 15->45 usually for a skyline gtr from 15-32+ offset
the width of the rim is usually written as 17 x 8JJ or 17 X 9JJ somewhere on the back as well.
hope i was helpful g'luck wif the sale
my 2cents
Thank you very much GTshortie! I will go home and check
my 2cents
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
