I'm going to change the diff and the auto gearbox oil in the next few days and i'm just wondering what other ppl have used or think what would be better. I've decided to go with RedLine products as i dont mind spending a lil bit extra for the quality.
At the moment i'm thinking heavy shockproof for the diff and i haven't decided which one for the gearbox. I'm thinking between the Hi Temp ATF and the Racing ATF.
Hi Temp would give me smoother gear changes than the Racing one but for the better shift performance i'm probably leaning towards the Racing ATF.
They say that the Racing one doesn't have any sliping additives so i'm not sure if it would be recommended for the R32 automatic gearbox.
Help please!!
https://www.sau.com.au/forums/topic/54114-which-redline-oil/
Use lightweight shockproof in the diff. The heavy stuff is too thick.
As for ATF, just stick with the Synthetic D4 ATF. The Hi Temp stuff isnt really worth payin extra for unless you want piece of mind. The Racing ATF will most likely prematurely wear out your clutch packs because it is not Dexron III approved.
I went with Heavy shockproof for the diff and its fine. I was told if i get any clanking noise from the diff to come back and they'll put some slipping additive to fix the problem - but there was no need for that.
As for the Auto gearbox, i haven't done it yet. I haven't had time and i'm still undecided on what to use. I was gonna go with Hi Temp for the piece of mind or Racing oil for that extra oomph but not sure of the side effects.
Has anyone used any of them???
I used lightweight shockproof in my diff and it seems to have fixed the occasional one wheel spin I was getting.
I also put Redline High Temp ATF in the auto and it sharpened the shifting a little but not heaps because I didn't have the pump you need to get the fluid out of the torque converter.
I think I'll go for Racing ATF next time but I want to make sure I've got some cash in reserve before I do it just in case. There's not many people know about R34 auto boxes.
I just got of the phone with one of the guys from Australan Distributors for RedLine Oils and he put a whole new spin on the situation.
His opinion is that more slipping in the automatic gearbox will give you a smoother ride BUT it also increases the gearbox wear.
He strongly recommends the Racing ATF, with no slipping additives, for the better shift response and loger life of the gearbox as long as i don't mind the jerk between the gear changes, which would feel like a manual driven car.
This is a 180 degree spin around from what i was thinking.
His name is John.
AUSTRALIAN DISTRIBUTORS – Red Line Oils Pty Ltd, Ph: 1300 88 1213 Email: [email protected]
Any thoughts on this?
Thats an interesting find. Maybe hes right, but I dont really like the idea of putting non specified fluids into something expensive like an auto tranny. His analogy is sorta like slipping a clutch. Slip and ride a clutch like 17 yo n00b in a festiva, then the clutch wont last. I suppose you can try the Racing ATF and check the shifting, but I reckon the HiTemp or D4 stuff is still the way to go personally...
I spoke to that guy too but I wish I had some other knowledge. Wait... doh! My dad is a mechanic...
ok just called him.
He said it would make sense that the Racing ATF with no slipperiness additives would produce less wear of your bands and such. If anything it might put more stress on your planetary gear set but due to their design they are unlikely to be a weak point. If you know how they work you will understand.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
