I am looking at BuyingLT-12 Microtech But want info if anyone has had problems with the unit.......... like fitting or programing! I really don't know much about ecu's but I have done most of the bolt on mods and I now want to tie them in all together and get rid of the flat spot in my boost curve.
Can you use the boost controller with the LT-12 Microtech. I am running a HKS Boost controller (older type ).
Question, Question .........need answers:D
Hi dude, Ive just had one installed. Sweet. No probs at all. I was quite concerned myself, as i heard some bad stuff about micro tech. This has proven to be a bunch of bad hear say. I nearly went a power FC over the micro tech, but with the results i got and the money i saved, im glad i didnt!
What turned my opinions around completely, was when whatsisname took me for a spin in his LT-12 equipped r33.
You can use the micro tech boost controller that comes with the computer -its electric, and uses the factory solenoid. -or you can use your own one. Whatsisname uses an HKS EVC with his LT-12.
I also had the flat spot you mention, actually due to the airflow meter and the stock computer, which is now gone. It now pulls clean and strong to the new 7500rpm redline. (the ECU also removes all your cuts -speed, revs, boost etc...)
Conservatively tuned for reliability stakes (no chance of pinging) it now makes 200kw at the wheels on 12psi, and the usual mods (turbo back exh, filter, NB changed the fuel pump to an 044 bosch)
Tuning and fitting were straight forward also.
cheers.
I should mention that the guys who fitted and tuned mine, at RPM perf. centre, are experienced with micro tech, which is probably why they got it right first time. I cant vouch for ease of tuning if done by a less experienced tuner, but ive heard they are pretty good. Hope this helps!
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
